E55 and E63 long tube headers
He said he only needs the car for a week, he's an extreme workaholic so hopefully when I get back from Vegas on Friday I can pick up the car!
If you go custom make sure the use 304 stainless. You also want a true collector not miter cut primary pipes. Use mild steel for the flanges. 1/2" thick if possible.
-m
It is not merely a biproduct of a larger crank pulley and/or s/c clutch. I felt a significant difference in supercharger engagement going from the LET tune to the VRP tune I had now. The harshness is effected by a number of things beyond just the mechanical parts - how the engine makes power and where it picks it up will also effect the "shock" felt when the s/c engages. If you are saying yours has not changed, I find that surprising.
I assumed that if Jangy were to add long tubes he would not have catalytic converters, you do have cats.
-m
i do agree there are more things that affect s/c engagement, but my point is that headers are insignificant compared to these other things. without changing anything else, my car went from very abrupt engagement to better than when it was stock just by upgrading the s/c clutch assembly.
you could be right about an exhaust smell with no cats...but the exhaust is carried out past the end of the car so i don't see how that would be a problem under "normal" driving.
I would say try to get with a good muffler fab place and have them custom a set for you. You should be able to get long tubes made for around 1000-1500K
