E55 and E63 long tube headers
We are having some custom setups made in Vista and I want something to compare it to. I also want to make sure we get it right since i wil be paying for labor.
I was talking to serge 2 days about this and he said that the only REAL disadvantage was the fact that longtubes eliminate the front cats. But trust me, its definitely worth the muscle car growl that only longtubes give you
I have been looking into long tubes for a while now, and I deiced to go with a custom set up that will bolt up straight to the resonator with no welding required.
btw, I think that jakpro and amgfan have VRP long tubes...
That is exactly what we want. How did it go? Smooth as promised? The guy comes highly recommended and does it right on the car, so I hope it will be solid.
What mods do you have on your car now...
I am in the process of getting a set on long tubes made up, I will post up when they are ready...
What does all the above babble mean? First off the above really affects NA motors much much more than forced induction. In the case of the E55 I would concentrate on a header design that does not change directions rapidly and is a true header not log style. Equal length is ideal yet not worth the extra effort in the case of the E55.
I respect your passion. From where I sit the Kleeman header offers enough of the desired features that I won't bother to fab my own. If the pre-cat issue has stopped you from making that choice I suggest you look closer and see what can be done for installing a pre cat.
Look forward to seeing whatever you end up doing.
I debated this as well, and I won't be going with long tubes for a few reasons:
1.) You will likely get horrid interior exhaust drone
2.) Supercharger engagement will become much more harsh
3.) You will not really have room for efficient catalytic converters and therefore your car will reek like gasoline fumes
After an exhaustive debate I've just come to the conclusion the E55 is not a car you run long tubes on.
-m
-m
1. i also have my resonator removed and i have ZERO exhaust drone. drone is a byproduct of muffler design rather than headers.
2. supercharger engagement is no different than any other car. harsh engagement is a byproduct of a larger crank pulley and/or s/c clutch. since i had my s/c clutch replaced with the improved version, engagement is dramatically improved.
3. ZERO gas fumes unless i'm standing right behind the tailpipe.
Mine is pretty quiet right now and I have the secondary cats cut. Will cutting the primaries make that huge of a sound difference? I want stealth and do not want growl.
Tell me why? Mine is already HORRIBLE enough that i am taking it back in and asking for another clutchpack. Tell me about this SC engagement, because we have to able to bypass some of these issues rather than choosing to stop pushing these cars.
Hold your horses. So, having no cats will make the car smell? Is this a for sure or only under certain conditions? I want to retain the MB feel so let me know.
-m
of course I do. I am not designing the headers, the guy at the shop is and I am relying on his experience. Also, we aren't exactly trying to tune it. i am really wanting to push it for top end even if I lose some low end.
SWEET!! I have left my mufflers alone!
Either way, i have the new clutch and the larger pulley. I have no intentions of going back now. if the headers don't make a difference, then better..
i have full long tubes, 1 set of 200ct race cats in the secondary location and no resonator and it's almost as quiet as stock with zero drone whatsoever during normal driving and only minimally louder at wot. it's absolutely perfect!!!
Is your Kleeman tune new? If not, I assume you have stayed away from any dealer flashes?
You may want to contact kleeman, if you don't already have a relationship. I've heard real good things from their recent tunes. You never know when even you can get more out of that thing....
Thanks for the advice.
I am going to get as full of a header as possible while retaining the stock location of the cats; I will likely however, replace them with higher flowing cats. When I talked to Rich a week and a half ago, he said he can build the headers so they will meet up with the cats at a flange and cut and reweld the cat with a flange on the other end so they can be bolted/unbolted and swapped with an off-road pipe for more performance/sound/personal preference.
I'm excited lol.
