I installed my front and rear Brembo GT brakes today. Bedded the pads in this evening and all I can say is the brakes are freakin' amazing. I'll post more on the install later.
All really went great except that I ended up with the brake wear message on my display because the wear sensors aren't mounted to the pads.
So I need some help. What I did was just plug the wear sensors back into the harness and tylok them up out of the way. Obviously, doing this triggered the dash warning message. How do I get rid of the warning, and how should I deal with the three wear sensors so I don't get messages in the future?
Any help appreciated!
Any help appreciated!Out Of Control!!
All the sensors are is a closed circuit. Doing what you did SHOULD have done it. Make sure they are plugged in right and that you didn't stretch one of them enough to tear a wire.
I have heard that it can be turned off by STAR SDS, but I dunno since it may be a safety thing.
I really think it is just faulty sensor or install
. BTW, mine are done up exactly as you said and I get no more warning.
