supercharger clutch problem's ?
Old Jan 3, 2009 | 11:51 PM
Ohbev's Avatar
E55 AMG Kompressor
Does the supercharger clutch ever stuff up. Like does it need to be changed so its not slipping to make sure you have full power like dose it need to be changed like a clutch on a manuel car ?
Old Jan 3, 2009 | 11:56 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
clutch will wear and bearings will eventually go. i definitely consider it a wear item that will need replacing at some point during it's lifetime.
Old Jan 4, 2009 | 01:49 AM
Pepsiguru's Avatar
2008 Infiniti G37 Coupe
Does anyone know the expected lifespan of a S/C Clutch ?
years....miles.... ?
Old Jan 4, 2009 | 03:10 AM
Ohbev's Avatar
E55 AMG Kompressor
if the clutch wears or bearings go will that mean the supercharger will not all ways be working
like if the clutch is very worn dose that mean it will some time ride and not make the super charger work hard or not work at all
like can a very worn clutch slip ?
Old Jan 4, 2009 | 03:18 AM
chiromikey's Avatar
i honestly don't know as not that many people have enough miles on their cars yet. in my experience, as my s/c clutch became more worn, the engagement became more abrupt. the bearing went out and the assembly was replaced before i got a chance to see just how far the clutch would go (mb insisted upon replacing the entire $800 assembly under warranty instead of the $15 bearing!?!?).
Old Jan 4, 2009 | 04:06 AM
bobgodd's Avatar
2004 E55
Are you referring to the bearing inside the actual S/C pulley? I was under the impression that bearing was not able to be replaced.
I've also been curious if the clutch was able to be turned? Probably a dumb question but meh. Also, when they replaced your clutch assy, did they replace the pulley/clutch piece along with the other mating end on the S/C side?
Old Jan 4, 2009 | 04:27 AM
chiromikey's Avatar
the bearing can be replaced...but mb will tell you otherwise.
i have no idea if the clutch can be turned and i don't know exactly what all is included with the s/c clutch assembly. they replaced it under warranty so i didn't ask any questions.
