street slicks much faster on a stock car
Old Jan 8, 2009 | 10:05 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by Ohbev
...So Is it better to take off with esp on or off??
depends on how the track behaves. if it's hooking well keep it off.
Old Jan 8, 2009 | 10:33 PM
bassn_07's Avatar
2006 E55 AMG
Chiro - how often do you hit the track and how many miles do you have or get on your T1R's? Just for the pure fact of preserving my street tires I'm thinking of getting dr's for the track. Also, what's the average life one should expect out of dr's, assuming you go a few times a year?
Old Jan 8, 2009 | 10:50 PM
cruzinquick's Avatar
2005 Crossfire SRT6
You guys probably can get away with a set a year if you only use them at the track. I am on my 3rd set, but have over 250 passes in just over 1 year's time. Also depends on what kind of burnout you do. the hoosiers only need a small burnout to get sticky. I still feel they wear out to fast.
Old Jan 8, 2009 | 10:58 PM
bassn_07's Avatar
2006 E55 AMG
WOW! That's a whole lot of passes in a years time. I don't know how often I plan on going but if I was to guess, at least 6-8 times a year. Would this justify drag radials if wear on my street tires was my only concern? I don't mind running with my street tires but I'm hoping to get at least 10k on them.
Old Jan 9, 2009 | 01:06 AM
chiromikey's Avatar
honestly, one of the main reasons i use d/r's is to save my street tires and if my car wasn't lowered, i'd get 20k miles out of my toyos.
if you only go to the track a few times a year, your d/r's will last a looooong time!
Old Jan 9, 2009 | 03:05 AM
2005 Crossfire SRT6
It depends on how busy the track is when you go. I run in 3 different race seasons. I get 3 qualifying passes and then single elimination at each race.. I've done well in the past and went 5 rounds deep on some nights. Usually 5 passes is the most I'd get. Now on test n' tune nights with no one there you could easily run 20 times and blow through your tires pretty quickly. When I'm not bracket racing I'm going for my own personal records. So eventually it's for best times and then you start to compare to others, and the addiction comes full circle. That's when drag radials come in, to set the best times with the best weather you'll need drag radials. Never waste great DA(density altitude) on a poorly prepped track. Those will be the fastest days of the year, unless you live near MIR.
Old Jan 9, 2009 | 03:56 AM
  #32
Ohbev's Avatar
E55 AMG Kompressor
Originally Posted by Hammer Down
Was....It still is stock. Out of about 10 runs I average 116.5 to 117.7 and 12.2 to 12.4 with the exception of two runs...my fan was on due to alittle heat and I ran 12.7@115.xx and another time I forgot to turn the esp back on after the burnout and spun & pitched it sideways the 1st 100' but still ran a 13.8@113
Hammer what year model is your e55 ??
Old Jan 9, 2009 | 03:59 AM
  #33
Ohbev's Avatar
E55 AMG Kompressor
Cruzinquick what mph did you get when your e55 was stock ?
Old Jan 9, 2009 | 06:10 AM
  #34
2005 Crossfire SRT6
No 55 for me. I have a SRT6. I drove tectite's car a few weeks back. It's not stock. Now have a buddy with one from Sedona, and his is stock. He's the one who ran 12.18 in a race against me. They have lots of motor similiarities, but it ends right there.
<----------------- See my car in the pic. It's the one in the lead.
Old Jan 9, 2009 | 07:39 AM
  #35
Hammer Down's Avatar
2015 E63S, 2018 E63S
04'
Old Jan 9, 2009 | 06:31 PM
  #36
Ohbev's Avatar
E55 AMG Kompressor
04'
Thats big mph for a stock car do you think my car would at least get 115mph stock my one is 03 model ?
Old Jan 10, 2009 | 01:06 AM
  #37
2005 Crossfire SRT6
The mph is decieving. You have to understand the 1/4 mile with 60' times versus mph at the top end. The quick version is the better the launch equals great 60' times and and the lowest et and mph. Slip off the line and you will have higher mph, but a slower et. I am trying to find my timeslip when I ran against the stock E55. Even with 12.18 I don't remember the mph above 114 on that pass. I scanned it, just have to find it. I gave tectite the timeslip when I ran an 11.88, so I don't have the mph. I'll see if he has it at Famoso and get you the mph. I believe low 120's if that.
Old Jan 10, 2009 | 12:50 PM
  #38
On that day up in Sac I had quicker et's & faster trap speeds than other stock E55's that had better 60' times then I did (I mean their 1.8x to my 1.97). The other guys said that my car has a nice top end because I was picking over 26mph from the 1/8 mile to 1/4mile. The only E55 that was faster was Sean (I think that was his name) and he was a stage 1 with DR's. I believe he ran a best of 11.8@118xx (I may be off on the mph)
correction Urfantasy ran a 12.20@110 or 111 to my 12.25 @ 117.xx
Old Jan 10, 2009 | 01:03 PM
  #39
bassn_07's Avatar
2006 E55 AMG
Thinking of getting some DR's for this weekend and I'm debating on BFG's or R888's. It seems that BFG's are considerably cheaper than R888's. Any input would be appreciated. Also, if I purchase 275's with a slightly lowered E55 would rubbing be a issue with stock rims?
Old Jan 10, 2009 | 01:17 PM
  #40
It shouldn't while you are going straight assuming that you are going to put these on at the track or will you be driving to the track with them on? I would go with the MT ET Street. I think they run about $450ish for a set of 265/40/18. Andy used those on his C63 when he ran 11.5 and he said that they are "sticky"!
Old Jan 10, 2009 | 01:28 PM
  #41
bassn_07's Avatar
2006 E55 AMG
Any recommendation on where to purchase? Hopefully somewhere close to the Bay Area to assure I get them before next Thursday. If I purchase the BF G's from Tirerack.com I could have them here by Wednesday.
Old Jan 10, 2009 | 01:35 PM
  #42
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
When trying to attain higher MPH's, the air pressure in the rear tires should only be as low as needed to get the car to hookup.
The said, your front tires can be set up to 50 lbs for less rolling resistance.
I've found by starting at 35 lbs on drag radials you may only need to drop 5 to 10 lbs depending on the track prep.
Last time at the track my 35 lbs went up to 40 lbs after a few good burn outs and that by just lowering it back to 35 lbs the car hooked up perfect with no wobbliness on the top end.
Just remember to take your air pressure gauge, and reset air pressure back to stock, before the drive home.
MachC5
Old Jan 10, 2009 | 01:41 PM
  #43
http://cgi.ebay.com/ws/eBayISAPI.dll...m=120319180616
there you go
Old Jan 10, 2009 | 05:26 PM
  #44
bassn_07's Avatar
2006 E55 AMG
Looks good but can I get them here by Thrusday? Highly doubtful coming from Michigan. There must me somewhere in Cali? Thanks Hammer down the effort is appreciated.
Old Jan 10, 2009 | 08:53 PM
  #45
Ohbev's Avatar
E55 AMG Kompressor
Do your remember what kind of mph the other stock e55 where getting
Old Jan 10, 2009 | 09:07 PM
  #46
2005 Crossfire SRT6
Just found the slip. He ran a 12.181 @ 114.019 all stock. His 60' was 1.782. Remember the better the 60' the lower the mph at the top. I remember the DA was about 2800' or higher that day. So a place like Famoso or Fontana that migh be a low 12.0 pass, possibly 11's with drag radials.
Old Jan 10, 2009 | 09:09 PM
  #47
2005 Crossfire SRT6
By the way it was this guys first time at the track.
Old Jan 10, 2009 | 09:18 PM
  #48
bassn_07's Avatar
2006 E55 AMG
Does everyone always turn off ESP when using drag raidals? If you're not breaking it loose it shouldn't matter...right.
Old Jan 10, 2009 | 09:21 PM
  #49
MB_Forever's Avatar
E63 P30, CL500 Sport
Actually Shawn (he's not on the boards) ran a couple of 11.70s at almost 120 mph that day . He was Stage 1 + drag radials. Now he's stage 3 and running 11.50s with one 11.48 His car needs some cooling mods (a secondary heat exchanger and maybe the spacers). He had talked about installing them, but I'm not sure if he finally went through with it
Old Jan 10, 2009 | 09:23 PM
  #50
bassn_07's Avatar
2006 E55 AMG
Originally Posted by MB_Forever
Actually Shawn (he's not on the boards) ran a couple of 11.70s at almost 120 mph that day . He was Stage 1 + drag radials. Now he's stage 3 and running 11.50s with one 11.48 His car needs the secondary heat exchanger and maybe spacers.
What was hit trap speed on the 11.480 run?
