Cooling Mods
Old Jan 18, 2009 | 07:58 AM
Brave7012's Avatar
E55
Cooling Mods
Hi,
Has anyone tried installing another OEM Behr unit on top of or in front of the stock unit. Any feedback to how well it works ?
This is for car with 178mm pulley + ECU
Old Jan 18, 2009 | 10:44 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
The radiator is large enough, the 3 cooling mods that are most popular are
1. 10 degree fan mod. software change fan comes on at lower temp.
2. Thermostat. Member PTE builds low temp thermostats.
3. Intercooler heat exchanger. larger heat exchanger for IC and better pump.
And yes here is an oem large heat exchanger.
And you can find more here. BTW search function is your friend.......
https://mbworld.org/forums/w211-amg/...r-project.html
Old Jan 29, 2009 | 02:02 AM
dpavid's Avatar
2005 AMG E55
Just did this mod today and noticed the fan coming on after a short 0-120 run. SWEET!
Old Jan 29, 2009 | 02:39 AM
NSX2NV's Avatar
03' E55 Techtite Grey
Is there any way to check and make sure that this mod is done? I recently had Mercedes do it and they charged me $50 bucks to do it. I want to make sure that it was done.
Thanks,
Ty
Old Jan 29, 2009 | 03:43 AM
dpavid's Avatar
2005 AMG E55
only way i know is to check settings using Star DS... Should say 10 degree. Factory settings is 0 degrees.
Old Jan 29, 2009 | 09:41 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i have cm30 pump, code3 HE and did a 5 degree star adjustment. that combo work well for me !
