- Mercedes-Benz E-Class: Why is there red battery message saying visit workshop
Guide to diagnose trouble and recommended solutions
"Visit Workshop" battery icon light
But after my car freaked out, it started again and acted as if nothing was wrong. I took the car into the dealer anyway & asked them to check both batteries. Both batteries checked out fine, but as I was about to leave, they were moving the car to the end of the service drive & the car would not start.
Based on the behavior of the car, the tech felt like it was the crank position sensor. They had to wait about half an hour to be able to restart the car & verify that the crank sensor was the problem & they did in fact have a code come up indicating that problem. So they replaced the crank sensor & I came back the following day & was on my way out of town.
Not too far out of town, I notice the accelerator is no longer responding & the tach is dropping. I was able to steer the car to the shoulder where it died again. I called up my service advisor & also roadside assistance to arrange a tow back to the dealership.
That was Friday. Today after work, I called to check on the car & they said they pulled the codes (again?) and found the alternator to not be sending the correct voltage. So they replaced the alternator, took the car out for a test drive, and everything seems fixed.
They get back to the dealership & the car will not start, again.
Right now, they tell me that they suspect that its one of the fuel pumps not regulating properly--incidentally, the pump actually in/near the fuel tank has already been replaced once due to the fuel smell issue.
Anyway, I'll keep y'all posted with what tomorrow finds.
True?
I wonder why this happen only when i stop using the car for 3 days !
Of course, this problem has now reared its ugly head in my car and there seems to be no real cause that I can discern for this problem. Any concrete news?
. I also lost my power steering and brakes a block away from my home. It really sucks but what could you do.
Same problem on E270CDI 2004.
Had both batteries renewed and also alternator working fine.
Light constantly on and staying on. SBC hold unavailable also.
HEEELPPPP - I need to fix it so I can sell it
Always happened in winter on nights when -0 or less.
Was told to put a larger amp battery 100amp iso 70amp on the back which fixed the problem, but then gave me the red warning problem.
Being told now that wiring looms need changing at a cost of £400 per day £50 per hour day rate
...Looked at the manual and read the following
Message - battery red lamp visit workshop
The signal circuit 61 cannot be read via the interior CAN (not got a clue what this is)
The message appears, if the battery control unit (N82) is defective, the alternator (G2), the additional battery relay (K57/2) or the additional (convenience) battery (G1/7) are defective....
So battery okay - now limited to Relay oe battery control module
What do you think???
voltage regulator, aux battery, battery isolator relay for aux battery, charged rear battery fully, battery control module in trunk
vr, aux battery, and relay made the red battery code go away.
charging the rear fully and replacing bcm made the low battery conve fuctions disabled go away completely. Car shows now 14.1v on FSS dash when car is running. Before was 13.2
I also purchased a new alternator if none of the above worked. Luckily it did.
battery test at home shows cells in battery are good so its got to be voltage regulator or alternator...
had to take it to the stealership this morning and have them take me to work... they are replacing voltage regulator now and hopefully that is the fix since they would have to order the alternator and that leaves me screwed for the weekend....
if its not one thing its another with these cars
.... thinking of getting rid of mine and going the porsche 996 911 turbo route and slapping an evoms 700 kit on it and calling it a day!
