Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Why is there red battery message saying visit workshop
Guide to diagnose trouble and recommended solutions
"Visit Workshop" battery icon light
Not sure if this has been discussed but thought I would help out others if it hasn't. If you get the message in the title (red color), there are 2 batteries in the car (I have a 2006 E55). One is the regular larger battery to start the car (in the rear) and a smaller motorcycle size battery located in the front passenger side UNDER the cabin filter by the firewall. Since I wasn't having any starting issues I changed out the smaller battery and the warning light disappeared. MB service guy said this is the battery that powers the dynamic seats and other electronics in the car. It's an easy DIY job w/ a 10mm deep socket for the entire job.
Jeff
Jeff
Jeff
Jeff
Damn, celebrated prematurely. The battery icon light came back on!! Since I am not having any starting issues at all I didn't think it was the big battery...maybe a dead cell?? Does anyone know if there is a need to "reset" the light? It also doesn't come on all the time. This leads me to believe I may have one dead cell or a partially dead cell in the large battery now.
Jeff
Jeff
Jeff,
The small battery in the front of the car is the starter battery that also powers a few functions such as ones required on startup. The main battery in the trunk is still the primary battery that the car uses when in operation. It is likely your primary battery needs replacing.
-m
-m
Jeff,
-m
-m
Jeff
Hmm, the service advisor at MB said the small battery in the front is not for starting but for the electronics in the car. It does seem too small to be used as a starter battery. Are you sure? Guess I will do a search on what you guys are using for the main battery. I don't even want to get a quote from MB on the cost of the main battery. Thanks for your help.
Jeff
Jeff
Just recently went throught the battery warnings only to have the car completely freak out and die. Turned out it was the alternator. I had the dash warnings as you described, only not in red, and was on the way to replace the big battery in the trunk when the car totally died about 200yards from the dealer. FYI, when the batteries both drain, you loose all power options in the car INCLUDING BRAKES. Remember that your accelerator and brake pedals are electronic, not mechanical.
Jeff
Yes the brakes fail! I was in the car when they did in my friends car. We were pulling off the highway and he said the pedal went to the floor for a second before the brakes engaged. That's when he realized he shouldn't have been ignoring the RED screen saying "Battery Visit Workshop"
Thx
Jeff
I don't see why not as long as it is the correct amperage and size. I don't think the computer is going to be able to tell a difference. If command says get this Duralast Battery out of here I'll give you my battery
...........It is ABSOLUTELY your alternator!! NSX2NV is completely correct. You are about to get stranded in the middle of the road. Trust me on this one. Get into you car and drive DIRECTLY TO THE SHOP. So long as your car cranks up, you do not need to change the battery. You can change the battery if you like, but every second you spend debating about the battery pulls you closer and closer to getting stranded on the road. The car WILL freak out and will totally die without warning, even if you are in the middle of the highway. YOU WILL NOT HAVE TIME TO PULL OVER!!! REPEAT, YOU WILL NOT HAVE TIME TO PULL OVER!!!
Ted
Ted
Ted
Ted
Jeff
OK, will have the alternator tested. The light has been on for the last 3 months but has been sporadic...maybe on about 75% of the time. Will get it tested and let the board know. Man, if it's the alternator it didn't last long as the car has 55k miles. NSX2NV and I are not used to this (I have a NSX as well) in the NSX!!
Jeff
Jeff
This is my first ever owned.
This is my Comptech SC one.
But never forget the Beast E55!
Jeff
Jeff
.......my car was 40,000 miles when it happened. I drove 600 miles from the initial warning till the time the car died in rhe middle of I-95 between FL and GA. Apparently the cars are engineered to give you fair warning. It is really scary when the car eventually dies all the christmas trees will light up and in less than a minute, the car will TOTALLY die. Yes, i did chane my main battery after i got the warning light. It was not the battery. Thw warning light came back. I thought at the time that the ECU just needed to reset. Wong! So, take no comfort in the fact that your car has 50,000 miles or that the warning light has been on for 3 months.
Ted
NSX2NV-Very nice rides!! I've also owned 2 NSXs..no pics of the first but here is a link to the story of my 2nd & current one. I am redoing the entire audio system on it now...will be ready by the end of the week.
http://www.nsxprime.com/forums/showt...ight=02+update
The E55 is actually my bro's...I've been working on it to help him out w/ his busy schedule. I love the car though. I have an 03' M5...I know the dark side for you MB guys Both cars are awesome IMO.
Jeff
Jeff
Ted
Ted
Thanks!!
Jeff
Ted
Ted
Thx
Jeff
OK, went to Autozone this a.m. They load tested the big battery in the trunk and "battery good". They also tested the alternator and it showed 14.0Volts. So, don't know what to do from here. Battery icon light didn't go on while I drove it there nor back (5.0 miles roundtrip)/.
Jeff
Jeff
Jeff
Jeff
Thanks!! The very last pic in the end is how it looks now. Goal was to be unique (rare larger Ctech SC, CF wheels, and custom one off AMG front brakes) on the main parts. The audio setup will be unique as well..will post pics in a week or so...can't wait.
Jeff
Jeff
2003 e55
Racer, had similar problem. When I got my Kleeman stage 2 installed, they hooked the intercooler pump up directly to the little battery in the front which by the way has nothing to do with starting. It does run SBC and some electronics as mentioned. Anyway, they did this so the pump would be always on, not just when the supercharger engaged. It ultimately kept draining the small battery. The same warning light you have would intermittently come on and then stay on when the battery totally failed. Later, even after replacing the small battery, the light would stay on. The problem was this battery's control module or relay that controls flow to recharge this battery burned out because it is basically a gate to direct flow to recharge the battery and the small battery was asking to be recharged constantly. The ecu detects when this relay fails and also gives you the red battery light warning. Perhaps your relay is out? If it is everything still works,but the light is always on.
Jeff
