Brabus SL wheels on a E55 for fun.....
Old Jan 24, 2009 | 06:39 PM
RenntechE55's Avatar
CLS55 AMG 030
Was bored the other day so i decided to try on the wheels off the SL on to the E. the offset is to radical for the e55 but it almost works ohh ya by the way the tire on the wheel is a 295/30/19 on a 9.5 inch wheel so with the right tire it might work.
Attached Thumbnails Brabus SL wheels on a E55 for fun.....-img_0277.jpg   Brabus SL wheels on a E55 for fun.....-img_0278.jpg   Brabus SL wheels on a E55 for fun.....-img_0279.jpg   Brabus SL wheels on a E55 for fun.....-img_0280.jpg
Old Jan 24, 2009 | 07:08 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
Looks like a little high.
Did you move the car a little back and forth??...this way it could be at his normal height.
Old Jan 24, 2009 | 07:11 PM
CLS55 AMG 030
no just put them on and dropped it took pics then took them off , cause it was getting dark. would rolling it set it or some thing? and i think the suspension was raised but i'am not sure
Old Jan 24, 2009 | 09:09 PM
Road Racer's Avatar
Yes. When you change wheels or just one wheel; you have to use the parking brake, right??... when you took the brake off drop the car a little, then roll it back and forth and you'll see the diference.
Old Jan 24, 2009 | 11:16 PM
CLS55 AMG 030
ok cool thanks
Old Jan 24, 2009 | 11:54 PM
velvet fog's Avatar
05 SL500, 02 BMW Z3 (Mrs. VF), 05 FJR1300, 91 ZX-11
Interesting... Stock SL tire size is 285 and you could go as low as 275 without stretching the tire.
Old Jan 25, 2009 | 12:11 AM
CLS55 AMG 030
meaning if the wheel had a 275 it would fit.........
Old Jan 25, 2009 | 03:02 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
wow 295 sounds pretty good for the e55!!
Old Jan 25, 2009 | 10:12 AM
velvet fog's Avatar
Meaning you could go to a 275 tire on that rim with no problems and it might improve the fit. The shoulder of the tire would stick out about 3/4 inch less and have less chance of rubbing on the fender.
Old Jan 25, 2009 | 11:18 PM
DirtyVegasMB's Avatar
'21 GLC63, '19 M5
Just get different (10mm) spacers from Brabus and that wheel will clear E55 just fine.
Old Jan 26, 2009 | 02:05 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
nice
I always wonder how aggresive the sl offset would be, looks pretty euro- If you run a 275 i think it would be fine
Old Jan 26, 2009 | 03:37 AM
OzE55's Avatar
2003 E55
Wont that make it worse? Isn't the problem that the wheel sticks out past the wheel arch already, so a spacer will push it out further.
Old Jan 26, 2009 | 12:20 PM
velvet fog's Avatar
You are correct. SL wheels have lower offset than E wheels so they stick out more. Spacers will reduce the offset even more and make the wheels stick out more. Unless you get the new Brabus "Black Hole" spacers
Old Jan 26, 2009 | 11:11 PM
'21 GLC63, '19 M5
Maybe Brabus made a different offset wheels for SL... back in the day all casts were the same and offset adjusted by spacers. My Brabus wheels are all sitting on 10mm spacers.
