Racing From a Roll
Old Jan 24, 2009 | 09:02 PM
ECBAOBAO's Avatar
nascar
Racing From a Roll
Hello,
I was wondering if there is any difference between just flooring the pedal to kickdown and holding the shift paddle to get into the lowest gear when racing from a roll.
I've heard some people saying to hold the paddle and it'll choose the optimum gear for the speed you are going, but then I've heard people say to go to the lowest gear possible.
Also, sometimes it seems like when I ease into the throttle when the car is in D it feels faster then when I just push down the pedal all the way.
Sometimes when I am completely off the throttle and then go WOT, the RPMs just climb w/o downshifting. However, if I ease onto the pedal it will downshift. Normal? I have done the "sneaky ecu reset" also.
btw, I'm also using a sprint booster.
Old Jan 24, 2009 | 09:47 PM
Max.H's Avatar
E55
always downshift to the lowest gear possible if you want to win. or you might be the one driving home with your tail between your legs. wondering what if.
Old Jan 24, 2009 | 10:39 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i always downshift myself - usually 2nd gear rolls
Old Jan 25, 2009 | 01:10 AM
alphanumeric's Avatar
ya, when you put the gear selector in 2nd, and it reaches red line... it will shift automatically to 3rd gear. this only works in S and C mode.
Old Jan 25, 2009 | 01:20 AM
ECBAOBAO's Avatar
nascar
Thanks guys.
How fast would you be going for 2nd gear rolls?
Old Jan 25, 2009 | 02:17 AM
go out and drive your car and downshift until it wont downshift anymore and figure it out =)
Hammer Down's Avatar
2015 E63S, 2018 E63S
Originally Posted by ECBAOBAO
Thanks guys.
25-30 with the traction control off and hold on
Old Jan 25, 2009 | 06:09 AM
NSX2NV's Avatar
03' E55 Techtite Grey
Hello,
If you hold your gear shift (actual shifter) to the left it will automatically choose the lowest gear you can run in. Optimum for rolling runs.
Quote "Also, sometimes it seems like when I ease into the throttle when the car is in D it feels faster then when I just push down the pedal all the way."
The reason I would guess you feel this way is because the peak torque curve is lower. Our cars make mad torque at around 2-2 1/2 K rpm, so down shifting will "feel" slower. Think of torque being a sprint, and horsepower being a marathon. Also you have a Sprint Booster so it feels like you're giving it half throttle when actually the S.B. is making it almost full throttle. Feels crazy for the driver but the same for the passenger. I still say 12 seconds flat with a S.B. is still a STOCK car....(PERIOD) I'll run 11's WITHOUT THE S.B. and K&N REPLACEMENT filters this spring!
Old Jan 26, 2009 | 10:13 AM
AMGTTV8's Avatar
2026 AMG GT63 Pro
put it in reverse!!
Old Jan 26, 2009 | 01:02 PM
phatmitzu's Avatar
2005 E55
Thanks guys.
Anything below 60mph.
Second gear redlines/shifts to third at almost 80mph.
Old Jan 26, 2009 | 01:38 PM
Marcus Frost's Avatar
Real Cars
PUT IT IN H!!!
Old Jan 26, 2009 | 01:44 PM
blackbenzz's Avatar
haters crazy
Wow, you guys have long gears!
Old Jan 26, 2009 | 03:40 PM
It's what keeps our cars slow!
Old Jan 26, 2009 | 04:24 PM
phatmitzu's Avatar
2005 E55
Yeah. Our 5 speed trans...
Old Jan 26, 2009 | 07:47 PM
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
7-Speed's are more FUN. =-0
Old Jan 29, 2009 | 01:17 AM
Ohbev's Avatar
E55 AMG Kompressor
i just keep it in s and jump on the throttle and the car will gear down to the right gear all the time
Old Jan 29, 2009 | 03:05 AM
Broker's Avatar
2003 SL55, 1999 Lexus LS400
Yes, with these being torquey engines down low, they don't feel the same as something that revs high. One example is with two different sport bikes I had... one being a 599cc inline 4 cyl, which revved to 13k rpm and the power would continue to build and build up until you bounced off of the rev limiter. But my other bike, a 649cc V-twin 2 cyl, had all of it's torque down low, like a muscle car, only revved to 10,500, and anything past 7500-8000 rpm, the engine would run out of breathing ability, feel like less power, and you would feel that you're shifting back into the powerband by upshifting. And that was a sporty high revving twin; most twins are on cruisers opposed to sport bikes. I would say the 55 AMG engine feels more like the latter of the two.
Old Jan 29, 2009 | 11:29 AM
blackbenzz's Avatar
haters crazy
You are costing yourself time by not having it in th eproper gear to begin with. It takes time to downshift
Old Feb 1, 2009 | 02:01 AM
Gondon's Avatar
02 S500 Sport
THX for this TIP.
I won a few races from a roll thanks to the technique.
It puts me into the right gear and I just ram it
Old Feb 1, 2009 | 03:01 AM
Skeeter's Avatar
2005 E55, Renntech Pulley, ECU
Hmmmm... I agree that it's best to drop into second at any speed short of 55 mph. And then let loose. Not sure I agree that from there it's best to redline and let the transmission shift into third. Feels like the car winds out and feels like having it in third at ~5K rpm, maybe a touch higher makes the car pull harder (using that massive torque). Seat of the pants at least, if feels like the shift slightly lower with our low down torque pulls harder than winding the pants off the motor into third. I'm not expert though.
Am I wrong? Should I just peg it out in M from second and let the trans shift b/c it hits redline?
Thanks,
Skeeter
Old Feb 1, 2009 | 01:57 PM
Gondon's Avatar
02 S500 Sport
It shifts b4 redline.
Old Feb 1, 2009 | 09:18 PM
III II I I AMG's Avatar
2003 e55
i found this out 2 nights ago on the hwy, me and a buddy's 335i with a crap load of mods...
i downshifted to 2nd gear in S mode... around 40mph, steps on the gas and shifts, when the rpm gets up, itll shift to the next gear by itself even though it already says 3rd gear, and results... i pulled on him strong, 2nd is definitely the strongest gear, you'll get the jump on people
