IS THE 80MM TB ENOUGH?
good stuff! i cant wait to see how it turns out!
im glad i didnt order the 80mm TB kit yet.
a couple questions.
will there be a way for me to still use my VRP CFairbox with this setup?
will i require retuning for this large TB? (currently have kleeman k2 flash)
a couple questions.
#35
With regard to a positive displacement blown app you want the largest possible TB you can fit on the blower, and overall the least possible restriction on the inlet side; meaning a large dia inlet tube(s) and massive filter(s).
#37
The key is to remove the restriction...
#38
VRP, MHP, Kleemann, Renntech, whatever. I dont care, someone make something!
#39
by inlet tube, do u mean the mouth of the airbox that connects to the TB?
#40
LOL...the man is desperate! Get him his TB now....I hear you ahmad!
#42
The bellows of an AMG 80mm TB are tiny as well.
#44
Everything you do to remove pressure drop up stream of the supercharger will reduce the temp rise at the discharge of the Supercharger. Thats where the horsepower increase comes from
#45
In my opinion only... opening up the cooler and shutting down the BP valve would yield massive gains compared to what minor inlet mods would do.
Those with NA setups would yield the best gains from a larger TB mod.
Proof? don't believe me, just check DTM and SLR figs which use similar heads and bottom end. Just the induction is altered.
#46
This is true but how much extra Hp is achievable by opening up the inlet ?... not that much considering the amount of cash you have to throw at the problem. A new 90mm TB costs x amount of $ for how much HP?
Then open up the TB as big as possible
THEN deal with the intercooler, that mod is going to make the TB look cheap!
Thinking about it the ECU MIGHT be limiting total load with the bypass valve. We might be off the ECU's Mathmotor map wrt the intake manifold pressure sensor... It would explain the ripsaw we see in Finny's logs.
#47
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
What's the point of building new intake parts now to achieve small gains when the main restriction is the stock cooler. Ideally we should be focused on building new Intercoolers first, then build the new intake mods around them.
#48
Gents I don't care what kind of car you're talking about, if it uses a PD blower opening up the inlet will gain power. The cooler may be the largest restriction, but that doesn't mean there aren't gains to be had with larger inlet, tb, filters.
Is anyone even doing anything for a 55k as far as intercoolers go? If not or until someone does you have to pick up power where you can, and the fact is inlet restrictions yield greater gains than exhausts or any other mod less a pulley in a PD app.
I agree with E55Pilot in that the cost of quality aftermarket intercoolers is going to trump the TB.
#49
TBs gain more power when paired with a PD blower than they do in any other application (N/A, turbo, nitrous, centrifugal supercharger).
#50
If we are talking about bang for buck... The software approach to shut the BP is the obvious choice compared to a TB upgrade and or induction mods.
I'm quite sure some of the Innovative after market suppliers are working on the problem right now and a proven solution should be available within 4 to 6 weeks.
