dirt in throttle body
Old Feb 10, 2009 | 04:16 PM
psk145's Avatar
2006 E55
I took apart my VRP CF airbox today to stick my stock filters until I could clean the foam ones they came with.
The TB was caked with dirt inside and even on the flap. Im assuming this is not normal?? Anyone else with the VRP box have this problem? Im I doing significant damage to my engine by letting that much dirt in? The box is sealed tight, and the only thing I can think of is the connection between the box and TB. But given the rigid design of the box, once its on, there's no wiggle room with it. Maybe I can get some duct tape
Old Feb 10, 2009 | 04:18 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
pics?
Old Feb 10, 2009 | 04:33 PM
psk145's Avatar
2006 E55
Originally Posted by Zod
pics?
I didnt think about taking pics.
Old Feb 10, 2009 | 04:37 PM
DFW01E55's Avatar
'14 ML BT
Use heat reflecting asbestos tape, duct tape won't take the temps.
Old Feb 10, 2009 | 04:43 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
definitely sounds like the tb and intake pipe aren't mated well.
Old Feb 10, 2009 | 05:46 PM
bassn_07's Avatar
2006 E55 AMG
I have the 80mm TB and the intake pipe definitely doesn't fit on snug like it should. My old TB had clips and the new 80mm doesn't . Any suggestion to a quick fix for this....Mike???
Old Feb 10, 2009 | 05:47 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
foam filters may be the problem
Old Feb 10, 2009 | 07:24 PM
bobgodd's Avatar
2004 E55
Could be a mating problem between the box and the TB, but I'm thinking its the crappy filters also.
Old Feb 10, 2009 | 07:47 PM
Max.H's Avatar
E55
+1 with shardul and bobgodd. Run the stock filters for awhile and check it again. Hope it works out
Old Feb 11, 2009 | 01:00 AM
Zod's Avatar
Zod
80mm MB tb has clips...u may need to order them....
Old Feb 11, 2009 | 01:11 AM
chiromikey's Avatar
assuming you have 80mm tb and stock y-pipe, pick up mb part #112-159-00-80 (it's a $3 gasket). it doesn't fit the 80mm assembly properly so you'll have to stretch it over your tb and then the y pipe will will friction seal around it perfectly.
Old Feb 11, 2009 | 01:33 AM
bassn_07's Avatar
2006 E55 AMG
I knew you would have a answer.... That thing we talked about will be going on soon. Maybe a couple of weeks...can't wait.
Old Feb 11, 2009 | 01:41 AM
BenzoBoi's Avatar
Super Moderator
W221
I never looked inside the TB to see if any dirt was in there...maybe I should do take a peek...
Uh oh....I guess I'll have to find a lil something something extra to do to keep up now!
Old Feb 11, 2009 | 01:54 AM
chiromikey's Avatar
Old Feb 11, 2009 | 01:56 AM
bassn_07's Avatar
2006 E55 AMG
LOL...your cars best time still has mine by .02 or so . I have the cooler box installed now and it seems to work great. I did a few hard runs and never went over 106, this was on a cold night 55 degrees or so. All kidding a side this next mod will probably be my last. No more money...
Just go nitrous and call it the day.... Be like Jcart.
Old Feb 11, 2009 | 12:07 PM
psk145's Avatar
2006 E55
thanks for the response. I hope its just the filters that arent up to par. If its the box itself, there's nothing I can do about it. I'll leave the stock filters for a few months and see what happens. I dont notice any difference anyway between the stock and foam.
Old Feb 11, 2009 | 01:02 PM
Zod's Avatar
Zod
there is an other thread about the filters...apprently its the oil i n them...I do nto have it so do not know
