removing impact strips??
Old Feb 10, 2009 | 10:17 PM
RenntechE55's Avatar
CLS55 AMG 030
has anyone removed the impact strips? is it a easy DIY job? thanks
Old Feb 10, 2009 | 10:18 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
I did to clean behind there. They just snap on and off. It is actually really easy.
Old Feb 10, 2009 | 10:23 PM
CLS55 AMG 030
so you just pry them off with like a flat head screw driver? thanks
Old Feb 10, 2009 | 11:07 PM
Marcus Frost's Avatar
Real Cars
Becareful with prying as you can damage the strips. They do come out pretty easy, but they do require care cause you can break tabs and can damage the strips almost just as easily.
-m
Old Feb 10, 2009 | 11:29 PM
CLS55 AMG 030
i noticed small screw inside the door jam on the door that is level with the impact strip does this have to be removed?
Old Feb 11, 2009 | 08:09 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
I think everyone incorrectly assumes that you are talking about the bumper impact strips. It seems that you want to pull the impact strips off the doors based on your last post.
I have never removed them but someone will have the answer.
Old Feb 11, 2009 | 08:17 AM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
If you are talking about the bumper strips let me know, i just did it a few weeks ago to put on the euro version... Let me know and I ll give you the play by play!
Old Feb 11, 2009 | 01:59 PM
CLS55 AMG 030
ya im talking about the both the ones on the doors and bumper i want to paint them black like evosport's white E55 thnx
Old Feb 13, 2009 | 08:04 PM
CLS55 AMG 030
ok got the door strips off but the only way to take the rears off is removing the bumper? is it the same for the front? thanks
Old Feb 13, 2009 | 08:09 PM
jangy's Avatar
2015 S212
I do not know about the rears, but the fronts just pop out. You pop out the part that is closest to each door (not the front). Then, you slide the thing parrallel to the bumper to release it. They have those L shapes hooks holding them in place on the front of the car, but just pop ins on the sides. Again, I am only talking about the front impact strips.
Old Feb 13, 2009 | 08:11 PM
jangy's Avatar
2015 S212
Please do post it so we can use. Are you talking about the fronts or all around? I know the fronts (from doing the Euro ones), but not sure on the cleanest way for the whole car.
Old Feb 13, 2009 | 08:13 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Rear Impact insert can be removed without the removal of the rear bumper
remove the sides first then the center impact
Old Feb 13, 2009 | 08:14 PM
CLS55 AMG 030
the sides were very easy there is a screw in the door jam for each door you unscrew it and and the slide the strip a little bit then it pops out on the rear door it is in the front of the door and on the front door its on the rear of the door. ill try taking out the front tonight
Old Feb 13, 2009 | 08:18 PM
jangy's Avatar
2015 S212
Well, it looks like it is all pretty easy so I'll strip mine, too. It had been painted but on the car and I have lots of chrome showing.
CLS55 AMG 030
how do you remove the back sides? hey how do you remove the hood emblem im trying to do it right now? thanks
Old Feb 13, 2009 | 08:28 PM
jangy's Avatar
2015 S212
The hood emblem has a simple hand tightened clip in back. Just pop the hood and look on the underside. Should be easy.
The rear ones sound similar to the fronts. Just be careful not to ruin them.
Old Feb 13, 2009 | 08:31 PM
CLS55 AMG 030
ok one more question how did you remove the front impact strips with put chipping the paint? i keep on chipping my paint.
Old Feb 13, 2009 | 08:41 PM
jangy's Avatar
2015 S212
Bro, do not chip the paint!!
I used a plastic knife. You pop out at the end closest to the door. There maybe two or three pops and then the thing slides away from the car to release the front portion.
Old Feb 13, 2009 | 09:20 PM
CLS55 AMG 030
so i tried taking the front off. i poped of the first four clips the two before the side marker and the two after then tried to slide the strip towards me but didnt budge?
Old Feb 13, 2009 | 09:54 PM
jangy's Avatar
2015 S212
Don't break it but you have to pull it a good almost half inch. They are L shaped hooks only.
Old Feb 14, 2009 | 01:12 AM
CLS55 AMG 030
well got the rear impact strips out . the hardest thing i have ever done lol cant feel my fingers. does anyone know why the chrome on the door impact strip is metal and the rear and front are plastic? thanks
Old Feb 14, 2009 | 10:24 AM
jangy's Avatar
2015 S212
Sweet find!! News for me. Powder coat them!!
Old Feb 14, 2009 | 10:37 AM
CLS55 AMG 030
yep already got them and sand blasted they came out to be a pretty cool color silver after sand blasting.
