Black Grille
How do you recommend painting the stock grille black to get quality results and prevent the majority of rock chips...
I was looking at the grille the other day and was about the start the project but held off.
I want to take the grille apart into 2 piece (chrome front and black back)… but as I looked at it I noticed there are a million little lock tabs…. Does anyone know the best way of taking the 2 apart without breaking all the tabs…. I know they tend to break real easy.
Next… I planned on sanding, priming and painting but what products do you recommend… I have used Rustolium Plastic for my emblems but wanted to get your 2 cents on that…. I worry about easy rock chips, I know its inevitable but… I just want to do it right the first time so I don’t have to do it every time a small rock hits it.
Thanks everyone !!
Thanks everyone !!
I took the grill off and, like Finney, took some time with a screwdriver to remove the chrome section from the black portion of the grill. It is not difficult, once you get it started. It is time consuming, however.
Then, I took course grit sand paper and sanded the chrome. Three coats of black spray paint and two coats of clear later and I was finished. The entire process took about 4 hours (I am not sure about this, but that is a decent guess.)
I decided to do it on my own, because I made an assumption (whether correct or not) that rock chips were going to happen. Based on that assumption, I decided that I would probably have to repaint the grill over time.
I have a 3 or 4 small chips and will probably do another coat when it gets warmer. I may be making this sound much worse than it really is, but if you are a perfectionist, I wouldn't recommend doing it yourself.
After I get it washed tomorrrow, I will have a better feel for how bad it really is now and give you an update.
Yes, it's reactive to the metallic layer only.
They were doing some other stuff for me and chucked it in for nothing. Not sure of the acid formulation though.
how durable will it be to outside conditions (i.e. salt, rain, car wash) ?
https://mbworld.org/forums/mercedes-...cs-inside.html
