cm90
Old Feb 19, 2009 | 09:27 PM
Ohbev's Avatar
E55 AMG Kompressor
cm90
Can a cm90 pump be used on the e55 and does it work all the time? Will the cm90 give your car more hp ? Since it can flow more then the cm30 and is all ways working to keep the temp low ?
Also does the stock pump work all the time or only when you are on the throttle. Like when you stop at the lights does the stock pump stop working ?
Old Feb 19, 2009 | 10:26 PM
BenzoBoi's Avatar
Super Moderator
W221
Yes it could be used on the E55. You can wire it so it works while the car is on and you can also keep it on with the car off. I don't think it'll give you more hp but it'll definitely make the car run more consistent.
Old Feb 19, 2009 | 11:34 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
If you are going to mod, pulley etc. then a cm90 and HE are in order. If not, look no further then a cm30.
Old Feb 19, 2009 | 11:42 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
there's plenty of debate on whether or not the extra flow of the cm90 compared to the cm30 is beneficial and there's no definite answer yet. it is my personal belief that the cm90 is not worth the trouble since you need to increase the size of the inlet/outlet lines for it to flow at it's rated capacity. i also believe it flows to quickly and doesn't allow the coolant sufficient time in the h/e to decrease it's temps efficiently.
the above is all my opinion and i have no facts to back it up so take it for what it's worth.
now contrary to popular misconception, our ecu does run the i/c pump almost continuously. many people were, and stilll are, of the belief that hard wiring the pump to run continuously is beneficial. because the ecu already runs the pump except upon cold starts, there's no need waste time or money on this project.
Old Feb 19, 2009 | 11:45 PM
Ohbev's Avatar
E55 AMG Kompressor
The only mod's i will do is pulley and tune nothing else so i guess ill just stick with the cm30
Any one know where i can get an asp pulley ?
Old Feb 19, 2009 | 11:57 PM
chiromikey's Avatar
member jbfmcar was selling them or k1motorsports. they're both the cheapest i've seen. everyone was on backorder but they may be ready to ship now. keep in mind, asp's new pulleys are 180mm so intake cooling could become a factor.
Old Feb 20, 2009 | 12:43 AM
Ohbev's Avatar
E55 AMG Kompressor
If i add the cm30 and 180mm pulley and change the head exchanger. Dont change any hoses or any thing just replay the heat exchanger to a larger one like the one code3 sells would that do the trick ?
how much psi does the 180mm pulley give you ?
Old Feb 20, 2009 | 01:10 AM
chiromikey's Avatar
i don't know the psi on the 180mm pulley. they just came out recently so there's not much info on it. a new h/e will definitely help but data logging is the only way to know for sure if your intake cooling is sufficient.
Old Feb 20, 2009 | 10:23 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Well the 180mm vrp pulley
should give you roughly 13psi in 3rd at 6k rpms and roughly 14psi in 4th at 6k rpms
Old Feb 20, 2009 | 11:22 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
i thought the vrp was a 175mm ?
Old Feb 20, 2009 | 11:44 AM
shardul's Avatar
Hmm as per the vrp dealer that installed my pulley it was 180mm. I will check to make sure and report back.
Old Feb 20, 2009 | 05:30 PM
shardul's Avatar
180mm comfirmed
Old Feb 20, 2009 | 10:52 PM
bassn_07's Avatar
2006 E55 AMG
As it seems, it all depends on where the pulley is measured.
Old Feb 21, 2009 | 01:09 AM
prodigymb's Avatar
180mm comfirmed
im confused
Originally Posted by vrus
175mm is the first size that was done.. 165mm is the next one I am going to make.
https://mbworld.org/forums/w211-amg/...nk-pulley.html
on their website the pulley pictured says it's 175mm
