Help: Car Went Into Limp Mode [couldn't accelerate]
Old 02-22-2009, 11:24 PM
ECBAOBAO's Avatar
nascar
I have a 2004 E55
Today I was waiting at a traffic light and when it finally turned green I started to go and halfway through I realized that the accelerator wasn't working. I'm guessing this is limp mode?
I pull over and restart the car and it worked fine after that. This is the first time that it has happened.
I searched the forums and someone else had something similar to this, but not quite and that was due to his engine oil temperature getting too hot. Mine was normal though.
Any ideas?
P.S. I have a sprint booster..maybe I should check the connection?
Old 02-23-2009, 12:18 AM
DFW01E55's Avatar
'14 ML BT
You fail describe what car, E55 or E63.
Old 02-23-2009, 12:21 AM
lauer87's Avatar
E550
+1, we need to know what car it is to help you out...
Old 02-23-2009, 01:53 AM
ECBAOBAO's Avatar
nascar
Sorry, I have a 2004 E55
Old 02-23-2009, 02:02 AM
Tritech's Avatar
E55, GT-R
2004 E63?
What's your location? Is heatsoak an option?
Old 02-23-2009, 02:04 AM
DFW01E55's Avatar
'14 ML BT
Were you beating on it prior to the problem?
If yes, have you changed your coolant pump yet?
If yes,did you use an OEM version or the Johnson pump?
If no, change the pump to the Johnson 030.
If the pump is working, it may be your crank position sensor.
Try searching on those terms and see if your symptoms are matched by others.
Old 02-23-2009, 05:12 PM
E55AMGGG04's Avatar
04 w211 E55
My car went into limp mode all the time because I had a bad johnson pump. You need the CM30 johnson pump.
Old 03-02-2009, 03:32 PM
Steve 90TTZ's Avatar
2003 E55
I read somewhere on this forum (can't find the thread) that the intercooler pump should remain running ofr 5-15 seconds after the key is switched off. Is this correct? I don't hear anything after I turn the key off. I am planning on ordering the CM30 anyway but wanted to check to see if I have the dreaded ic pump failure.
Steve
Old 03-02-2009, 03:37 PM
bobgodd's Avatar
2004 E55
Steve
It's quite obvious if you do in fact have the intercooler pump failure. Find some open road and run from 0-120.. then stop and do it again, and again. If on the third run your car is still pulling hard, your intercooler pump is most likely fine. I knew when my pump went out because on the second run my supercharger would not engage due to the temps being too high (pump failed). You will feel the absence of the supercharger, the car will be significantly slower.
Old 03-02-2009, 05:12 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Check pump and sprint booster connections.
Old 03-05-2009, 09:58 PM
ENTIZY1's Avatar
05' E55 AMG
its your intercooler pump they go out I had to replace mine at about 35k miles. go to the dealer its cheap. or hit me up bro, you have my number
-Neil
Old 03-05-2009, 10:28 PM
e55 baller's Avatar
W221 S65 AMG
please better describe the issue. If your "accelerator" isn't working then if you floor it it will take 15-20 seconds to get to 20 mph - its insane. Issue is pedal sensor position. If you don't have the "full" HP then its a cooling pump issue. the two issues feel and are VERY different.
Quick Reply: Help: Car Went Into Limp Mode [couldn't accelerate]
