Question for Quaife Owners?
i'm in total agreement that an lsd is far superior to an open diff. however, my oem open diff never had any problem putting power to the ground evenly. it always spun both tires during burnouts, never ever had any pushing to one side off the line, and always launched hard and straight as an arrow.
1 Post
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
I have to agree with Mikey...the LSD is really only good for putting the power down evenly when you are in turns - the factory setup is totally adequate.. If you wanna REALLY hook get a locker. But, locking difs suck in ANY turn.
There should have been a LSD in the car from the factory, instead they decided to save money and do it electronically.
All those electronics do is reduce power to match the available traction for the one driven wheel.
A LSD distributes power to both wheels from the start so rather than trying to pour 500hp thru one tire now you are putting 250hp thru each tire. Which do you think will actually support more traction?
For a high horsepower street car you need a LSD, to suggest anything else is irresponsible
2015 S212
The one wheel spins weren't ESP kicking in. they were because the track was not wet and the difference in power being put down got exaggerated. The point in a 1/4 mile drag is to get the power down. Since mikey is already doing that, the LSD did not help. BUT, for those of us that are less consistent, the LSD would help raise our consistency by mitigating a spinning event ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Hey OP!! psu!!! Did you mean for the 1/4mile track or just to have? i don't think I'd get it for Famosa. I want one for every day.
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
i know the op is asking about this mod in the context of the drag strip. like i said before, i'm in total agreement that an lsd is superior to an open diff. i've just not been able to prove a performance advantage at the track since our oem diffs don't behave like the open diffs from the muscle car era.
as i also said, i'm willing to accept that my e55 was the exception and not the rule.
04 E55, 12 GL 450(wife)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#32
An example of the traction my car puts down is what happened at Famoso. I have everything in my car aside from cams. I was running on a full tank of 91octane, my mistake and 19' wheels with 275/30 PS2's.
My car ran: R/T .343
60' 2.097
330 5.416
1/8 8.102
MPH 91.66
1000 10.406
1/4 12.326
MPH 119.12
I have seen E55's run 116 & 117 in under 12 sec in the 1/4. So, I am assuming traction is to blame?
60' 2.097
330 5.416
1/8 8.102
MPH 91.66
1000 10.406
1/4 12.326
MPH 119.12
#33
2015 S212
I think you will love the quaife in the real world.
#35
2015 S212
Most important is install. I've seen a few with issues that never quite worked out. Shims here and there.
No need to ship. I can't believe I'd say it but you can get it local for that price.
#37
1 Post
I didn't ask you to...
Others have run both and seen NO performance gain as evidenced by Mikeys first hand comments.
It's much less due to drivetrain loss actually...
Irresponsible ??? Were not giving legal advice here dude
#41
#42
Engine:
Kleeman LT headers, primary cats deleted, Renntech pulley, 80mm TB, K&N drop in filters, code 3 HE, Hi performance wires, Johnson pump, Kleeman ECU, resonator delete, modified exhaust. I think thats it.
The Rest:
19' DPE on PS2's, evosport rotors & EBC red pads, Optima lighter weight battery, some CF add ons and a carlsson LM
The Rest:
#43
'05 E55 (Iridium Silver/Charcoal)
Hi guys,
I just joined the forum to find out some info regarding installation of Quaife LSD on my E55.
Now I see some of You have one installed, so I would like to ask if there were some issues with the Quaife installation or not.
I mean electronics issues like reprogramming ESP and mechanical issues - if there areany problems with installation, some modification to related MB hardware needed... I hope it is just smooth plug & play procedure but somehow it seems to me to be too good to be true.
Any recommendations, hints, tricks? I plan to have it done by local MB service. Is there anything that they should order or just the Quaife unit alone is enough?
Thanks in advance...
Btw. I was thinking about AMG original or Brabus LSD but I don't want to spoil everyday driving / curve comfort...
#44
Hi guys,
there are no tricks to the install, it should be almost plug-n-play. many people didn't even need shimming. just make sure the person doing the work knows what they're doing and how to set the backlash and you'll be good to go.
#45
the quaife is a better unit than both of those...at less than half the price.
In a meantime I have gone through some threads regarding the Quaife and it seems to be a must for E55. Also better brakes seem to be necessary, I had overheated the stock ones few times, it is much too easy to do...
#46
2015 S212
Thanks for advice!
In such case I would better search for some other service than the local MB, since I am sure they do not know what Quaife is. Maybe the Quaife dealer will install or advice someone experienced.
#47
#48
2015 S212
Absolutely. I'd have an MB tech do it over someone who does Quaifes anyday. I'd rather they know about the car. As chiromikey said install is CRITICAL. A bad one and you will forever be troubleshooting and or living with quirks...
#49
1 Post
'09 E63 AMG sedan (sold); E36 M3, E90 M3
having my quaife installed in the next few days. Why do it? well the usual ones for road racing (which i plan to do some of), and for inproved power deliver in straight lines (though some argue less of a benefit here, but i dont necessarily mean to restart that) but also, and very imprtantly, I am driving using her all winter where we get snow/ice (with dedicated proper snow tires of course), and in this setting, I think it should really enhance the overall experience.
Anyone else drive a Quaife-equipped E63/55 in cold weather climates?
#50
Quaife is a very nice addition to the car. Points to note....
It will not make you get more power down when weight is evenly applied to both rear wheels and both wheels have the same level of traction. It stops the unloaded wheel from spinning and washing all you power into smoke. Both wheels might end up spinning but at least your loaded wheel is working hard. It basically allows you to get the power down out of corner/in corners much (MUCH) earlier and with alot more confidence. As a result the car is easier to drive hard, and to balance.
Even in a straight line ESP intervenes much less, but still comes on of course.
Fitting is relatively simple but getting the pumpkin out is non trivial. Lots of heavy bits to move about and the plug in side shafts mean one rear wheel carrier has to come off. This means one rear brake caliper has to come off... and those bolts can be very sticky...
Typically no shimms are required, but you need to have this done properly to make the unit last... you have to check backlash... It seems they are mostly plug and play.
Nothing to do on the ECU / EGS fits into the electronics seamlessly.
When you fit it consider getting 2.82 gearing, or getting a donor SL55 diff fitting the Quaife to that and re-re ing the diffs. I know there are some EGS concerns which you need to take into consideration, but while you have the unit out off the car its something to consider. I am not looking back at all right now...
even though the EGS is not 100% resolved - not gearing wise - but sharpened shifting times and load limits have made the car very "unsmooth".... this is still a WIP.
