Air Pump Problem
Old Mar 3, 2009 | 09:13 PM
Yobi1Kanobi's Avatar
E55 AMG
Air Pump Problem
Got my 50k mile tranny and diff service and had the shop run for code since the CHK ENG light was on.
He came up that the Airpump and Relay are setting off the code. Is this something that I can do myself or am I going to have to pay the piper.
Anybody else had this problem? What should I do its like 540 bucks in parts.
thanks
Old Mar 3, 2009 | 09:21 PM
jangy's Avatar
2015 S212
Find out what the parts are. Are they replacing those parts or doing something with coding? Is the car an '03? Maybe just coincidence, but this will be the 3rd '03 with this issue in 3 months.
Old Mar 3, 2009 | 09:45 PM
E55 AMG
yes it is an 03. they are replacing them
Old Mar 4, 2009 | 11:11 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Might be covered under Service Campaign 2006030011 -
Old Mar 4, 2009 | 12:56 PM
jangy's Avatar
2015 S212
I figured as much. Would they honor the campaign for you? You should ask, since they often do on cars out of the warranty period. After all, it is a known issue.
Old Mar 4, 2009 | 01:30 PM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Is it acting strangely, or is it just the code? I have a 03 as well, but apparently the air pump on mine is under lifetime warranty.
Old Mar 4, 2009 | 03:03 PM
E55 AMG
its just a code I cant tell anything different
Old Mar 4, 2009 | 05:21 PM
jangy's Avatar
2015 S212
The car should drive the same although I dunno if it affects the tune or emissions at all.
I say check into the warranty. ALL '03s WITHOUT updated ECU flashes COULD have the issue...
Old Mar 5, 2009 | 04:52 PM
E55 AMG
I called the dealer today and they said they have no record of any open recalls for my vehicle. So they scheduled my to come in and see the problem. Should I take the bulletin with me. And do you think this should be covered even though I am out of warranty?
Old Mar 5, 2009 | 05:00 PM
jangy's Avatar
2015 S212
Yes, take the bulletin in and yes it should be covered, IF your simptoms are the same as the bulletin. On the DTB itself it says what to "look" for so be sure that you explain the problem in that way as well. They play games with "understanding" what you are saying and don't relate it to the DTB.
Old Mar 5, 2009 | 05:01 PM
jangy's Avatar
2015 S212
BTW, your ECU is stock, right? If not, the tune is a big issue.
Old Mar 5, 2009 | 07:09 PM
E55 AMG
Yes stock (as far as I know) I just got the the car last month. And yes the car is as describe in the bulletin. Check Engine is on.
Old Mar 6, 2009 | 02:43 PM
jangy's Avatar
2015 S212
Cool, then take it in and let us know. Make sure they check to see that you do indeed have the most recent MB flash. That is another way to cure it.
Old Mar 6, 2009 | 07:28 PM
E55 AMG
Thanks I will let you guys know how it went.
