I figured this would help prospective buyers like myself know what to expect in future repairs and compare this to current maintenance records on any E55s we look at. For example:
- IC pump 35K
- Airmatic shock 44K
- Alternator 50K
- IC pump 35K
- Alternator 50K
tires 13K
free oil change 14k
free oil change 14k
free oil change 14k
free oil change with new drain plugs 14k
recall air pump 16k
recall fuel pump 18k
recall cats 18k
Air matic strut 20k
free oil change 14k
free oil change 14k
free oil change 14k
recall air pump 16k
recall cats 18k
Air matic strut 20k
oil sending unit, 65k
serpentine belt 65k
SC belt 65k
lower ball joints 65k
Control arm bushings 65k
serpentine belt 65k
SC belt 65k
-oil level sending unit 40k
-s/c pulley bearing 97k
-alternator 99k
-alternator 99k
Max.H
close
- Join DateNov 2007
- LocationSan Diego
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveE55
Liked:39 Times in 38 Posts
All service was done at fletcher jones prior.
Oil change and fuel filter/pump replaced at 55k
Oil change and tranny fluid/filter replaced at 60K
Oil change and intercooler pump at 65k
Replace front thrust arm bushings and front tires at 68k
Oil change and Oil level sensor replaced at 70k
I could use a new superchager clutch and belt shortly. Valve cover gaskets starting to show signs of weapage, (not leaking) Rear diff seal starting to look damp. (will need to keep an eye on that)
i've done pulleys, belts, alternator, airmatic struts, brake reservior, brakes pads and rotors which is pretty normal, A/C condensor.. so far thats all i can think of, too many to remember.. car have been in shop many times, costed me over 10gs in repairs so far, and im just a couple hundred miles away from 80k
Knock on wood....58K miles, nothing. scratch that. At 48K or so, I had something with the pulley, I forgot what it was, but it was replaced under warranty. I replaced the belt at the same time.
I've had the car from 42K miles till now (58K). While under manufacturer warranty I had a lot done as preventive maintenance due to a good relationship with my service advisor.
42K Oil change (wanted to start off fresh with AMSoil), supercharger clutch pack, two door handle sensors replaced
48K Oil change, major fluids change (trans,brake,differential), two interior trim pieces that had hairline cracks/scratches, STAR lowering and seat belt chime removed, newer IC pump installed also, some fuel national recall work done also
55K Oil change, some electronic trans plug replaced that was causing leak and they did a full trans service along with replacing pan, did supercharger clutch pack again after I complained it was still rough engagement along with new belts (extended warranty covered most of this)
Is all I can remember for now.
Explore
