Getting rid of the front plate
Old Mar 11, 2009 | 09:40 AM
teolax's Avatar
2007 E63
My car came with the front plate installed and I can't stand the look. Does anyone know how much a body shop will typically charge to fill the drilled holes and repaint the bumper? Thanks in advance.
Old Mar 11, 2009 | 09:42 AM
Fr33kn63's Avatar
E63 AMG
dunno. I had same issue. car came with holes. It it were me, go hit a pole and mess your bumper up, call insurance company and get them to pay for new bumper
Old Mar 11, 2009 | 10:00 AM
teolax's Avatar
2007 E63
I'm thinking the body work would come in cheaper then my deductible...
Old Mar 11, 2009 | 10:06 AM
01bolt's Avatar
01 lightning,05e55amg
I was quoted $300.00 to remove cover fill holes and repaint
Old Mar 11, 2009 | 11:07 AM
baldmike73's Avatar
i went to bumperplugs.com and got color matched plugs for like $30 - check it before filling and repainting.
AudiOn19s's Avatar
A4, M3, 996, E55
Bumper Plugs?
Or actually you can just go to home depot and get blank hold plugs and spray them yourself if you'd like a less expensive option. It's not a perfect solution but looks much better than the alternative.
Old Mar 11, 2009 | 12:18 PM
veightkiller's Avatar
335i e90 / C63 / R6
i'd say around $100-$150 if you want a spot fix.
Old Mar 11, 2009 | 12:36 PM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
+...1 same here
Old Mar 11, 2009 | 02:09 PM
GERMANAUTOBODY's Avatar
If it runs I'll drive it
If you goto your local Mercedes Benz Service dept I think they do that for free... They do it here in San Jose, California <-- that's for installing licenses plate.
Old Mar 11, 2009 | 02:15 PM
They wouldn't. It would be like an automatic replacement. If you really want to repair it get it done the correct way.
If not and you want the cheap way out you might want is get a some cheap material (ie. plastic, rubber... etc) inserts tape/glue it in front behind. Or even do it yourself. Apply some body filler, do the prepping work, and do it yourself.
As far as cost depends on your location. Where are you located. Body shop labor varies by location and on body, refinish, etc...
Old Mar 11, 2009 | 02:23 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
DIY it for now...
when u have more rock chips, then go to the body shop for repaint...
Old Mar 11, 2009 | 02:40 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Originally Posted by AudiOn19s
Bumper Plugs?
+1... good enough for me And I spent like $1.5 per pair. Smaller than bumperplugs.com... and you still have some flexibilities re-installing your plates if *knock*knock* you get a fix-it ticket
Pardon the dust on the grill and the mess
Old Mar 11, 2009 | 02:42 PM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
I paid $400 to get my entire front bumper sanded, to get the rock chips out, and repainted, and while they were at it, they plugged up the license plate holes....
Old Mar 11, 2009 | 05:36 PM
rkao's Avatar
'12 ML350
Oh I got it done the cheap way: my wife rear ended a Honda CRV on the Henry Hudson Pkwy in Manhattan when the car was only 3 months old, which necessitated the replacement of the front bumper - so the MB dealer body shop left the plate and mounting bracket in the trunk of the car in case I ever got stopped (haven't yet...knock on wood) and threw in a new hood with the repair!
NJ state legislature is supposedly considering the repeal of the front plate requirement, but haven't gotten the final word.
I've received several positive comments from MB and non-MB owners who've said the remodeled W211 front end with the 'beak' looks better without the front plate mount.
