Keyless Go Problem
Keyless Go Problem
New here and I did try the search function.
I have a 2007 E63
When I get in the car the cluster says Check Key Battery. Just put new ones in like two weeks ago.
Any help trying to solve this would be appreciated.
Thank You
I have a 2007 E63
Thank You
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
What exactly is your problem with the keyless go? You can't lock or unlock your car?.....???
The battery might be bad?....Why don't you try changing out another battery and see if it still gives you the same message on the cluster panel.
Everything works with the Keyless, When I get in the car and hit the button on the shifter the instrument cluster tells me to Check Key Batteries, which are brand new 2 weeks ago.
Thank You
Thank You
I agree... Change the battery, you might have got a bad one. Also make sure it's the correct battery with the correct voltage.
One of the batteries was put into the holder backwards. Take 'em out and put them in again. should be good to go....
2007 E63 AMG, 2012 F250 4x4
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
