Joining the Bluetooth confused - 2006 with teleaid but don't see a UHI in trunk
Old 04-13-2009 | 09:26 PM
Bellevue_E55's Avatar
2006 Mercedes E55
So from what I see in the forum it seems I would need the UHI and associated cabling.
Reason I am asking is I have seen a couple posts about cars without phone prep that have teleaid and it mentions to just get the puck and pigtail.
Is that because they were prewired ? If I have a 2006 then I need the full setup with UHI ?
Thanks!
Need to post pics soon. Just got a 2006 E55 - Silver with Pano
Old 04-13-2009 | 10:41 PM
Thericker's Avatar
V12-Biturbo
Thanks!
Take a quick pic' of the inside of your center console & post it here, I can tell you in a sec what you need for phn to be turned on. Just being 06' it should be equipped w/UHI (if you can't take a pic' do you have a flat plug-in port in center console about 2"x2" blk plastic female plug-in port in center top area of console?) if yes you have UHI if nothing? you have NO pre-wiring
Old 04-13-2009 | 11:02 PM
bobgodd's Avatar
2004 E55
I might be wrong here, but I'm pretty sure the bluetooth puck with tail only applies to 03-04 cars. Your car would need something different.
Old 04-14-2009 | 01:32 PM
2006 Mercedes E55
Thanks Thericker
I have a virgin console with no connector. I also popped the plastic cover in the trunk and did not see the UHI module. I see all the cables like the pdf upgrade document on the 2005 model shows.
Guess I am going mobridge. Does it use the factory mic ?
Old 04-14-2009 | 04:56 PM
Thericker's Avatar
V12-Biturbo
Hmmm try the Viseeo home site http://www.incartronics.com/MBMost.h...Class=SL&VIM=1
They have a few solutions for peeps in your situation, scroll all the way thru the main page & I'm certain you'll find a solution, if too expensive copy/paste the item to Ebay to see if any sellers have it cheaper
Quick Reply: Joining the Bluetooth confused - 2006 with teleaid but don't see a UHI in trunk
