Aftermarket or replacement stock hood?
2005 e55AMG
Anyone have a source for carbon fiber or even fiberglass hoods for a w211 e55?
How about a good place in Texas (even a junkyard?) to find an obsidian black one?
2003 E55 & 2014 GL550
I still can't believe NOONE has come up with a hood for our cars with air inlets for venting or even possibly a hood down to TB closer connection.
Tuner showed one off awhile back at Sema wasn't it?? White car with black inserts in the hood.
We all freaked and were ready to buy and never heard another word.
E63 P30, CL500 Sport
2015 S212
Hmmm, I dunno about the CF hood thing. Yes, i like the vent idea, although those are out of place (visually and for performance).
What does the OEM hood weigh anyways? I think I remember it being just over 20lbs, is that true?
Also, what happens in a head on collision when the thing doesn't crumple like the OEM hood would. I don't want my head cut off for looks. IMO this whole CF thing is getting waaaay out of hand and useless. There are very few truly CF products out there. Most are heavy overlays on fiber glass or the OEM part.
C63, Grigio Medio E46 M3
Thats is he Vorsteiner prototype hood.. Think the idea was scrapped.. If i remember correctly, the one on the car in the pic is actually a modified OEM hood, not CF
Former Vendor of MBWorld
C55,SL55,C63
I think hood vents are almost a must for cars out here in AZ, Like mine, Mikey's and others. I'm going to a body shop and have them bust out the saw and start cutting.
Does anyone know of any good vents or a place that sells vents that can be molded to the hood?
E350 Sport & Rs6
I will get you an OEM Price in the morning! Then compare it to a CF hood (if one). You know, you might as well go lighter. Where are you in Texas?
2005 e55AMG
Central TX/Austin Area but will be in DFW for DMB (and hopefully some Gumball3k) on 5.1.
I like the CF idea, as with the TB location the car is begging for a cowl induction/ram air setup.
Remove the air boxes and inlet tubes and free up a bunch of space. A simple filter and air box integration that grabs the nice cool dense low pressure air at the base of the windshield and pick up a bunch of power.
So many ideas, so little operating capital. AND i wanna drive the damn car everyday.
I'm afraid OEM is going to be $$$$, I can get a CF from VIS (decent experience with BMW parts) for under $1000 without negotiating yet...
CF would be for weight and workability, but I'd probably end up painting it obsidian. I like a nice quiet stock looking car. I even have the CF trunk lip sitting in the bedroom as I'm torn on whether to install or leave it off.
Car is debadged on stock chrome split 5 spoke 18s.
2015 S212
If you guys end up cutting, please make sure you hit a high pressure spot, like OP said. By the windshield is the highest on our cars, not where Vorsteiner had them. Also, check for fitment before you commit. The OEM one fits perfectly. The CF hoods I've seen don't. Dunno why BMWs have good luck and our parts suck. My front lip is a $1200 piece of CRAP.
2005 e55AMG
Seems the stock TB location is just about centered in front of the OEM "vent" in the rear of the hood...close enough that stacking two of them back to back may cover and give the inlet we're looking for. Now to filter and weather proof that air
keep in mind that the vorsteiner hood has venting to remove engine heat so their choosing an area of low pressure was the right choice.
2005 e55AMG
Right-I'm thinking a high volume cold air induction would be worth more than heat extraction. Amazed the car breathes through the two snorkels.
2005 e55AMG
Oh I know all about the TB gains. Mine will be done by this weekend
2005 e55AMG
You have to remember that some people like to drive in the rain. And where would you fit a filter? Is there enough space? If you have an opening right before the TB you will suck in water when it rains.
Think more along the lines of a slight cowl induction hood...like the muscle cars used to have.
And there are definitely ways to prevent water ingestion...a bowl under the inlet with drain holes and the filter sucking up.
I have a few ideas-just need time and a daily driver :-)
Unfortunately aesthetics come into play on the exterior portion of the car
Definitely fit a filter...
Mercedes,Porsche etc
going with a CF hood makes alot of sense,, it saves about 21 lbs
add a CF trunk and thats another 19 lbs saves
40 lbs would give you equiv of about 5 add hp, general rule of 7 lbs shed = 1 hp equiv.
lose your spare tire and took kit thats another 40 lbs,,
change out the resonator and mufflers and thats another 55 lbs..
so around 140 lbs can be shed, which lambo and ferrari,
and aston martin all so on their sport racing models and charge $40,000 more.. for
its a great way to get more speed and lighten the car..
I have done all the above and more and can tell you the car handles better and is about 3/10 a sec quicker.
total cost less than $2300, not a bad tradeoff..
Or frame work? Shaving?
