Is going 3" from the primary cats back too much
I am going to possibly get a custom exhaust made and have already purchased the mufflers and tips which have 3" inlets. Will doing my whole exhaust after the primaries all the way in 3" cause me to loose low end torque and HP. Right now I am making stock power but have a eurocharged 180mm and LET tune waiting to go in.
Aleksander, I know you want this route for a while man, maybe you could chime in bro
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
you will definitely lose low end tq although it may not be too bad since you're leaving the largest exhaust restriction after the manifolds in place (primary cats). it will be up to you if you can live with the trade off of possibly making it up on the upper end hp.
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I like low end torque, because majority of the time you are driving you are in the low to mid range rpms, so loosing that torque is something I would not want.
2015 S212
Mine is cut from the primaries back and I love it with the tune. Agreed that you lose low end, but BARELY and the top end gain is large (in comparison). Before, it shifted much slower and now the taq hits the limiter much harder. I would NOT do it on a non-modded car unless you just like the sound which is also minimal. Gutting the mufflers is the only way for that.
after reading this I may just get the tapered pipe going into the primary cat opened up like Vadim suggested and eliminate my resonators. My muffler setup is going to be VERY aggressive so I am not worried about it still been quiet. Do you guys think from where I run the 3" piping to replace the resonator, if I continue that all the way out the back to the mufflers and tips I will still loose low end torque?
hard to tell. the stock system is 2.75". in some areas of the system the piping is reduced to a diameter smaller than 2.75. So if you go with a 3" mandrell bend piping there will be a reduction in torque. also remember the new mufflers will be more free flowing than the stock amg mufflers.
2015 S212
2015 S212
Mercedes
Aleksander, I know you want this route for a while man, maybe you could chime in bro![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I didn't notice a difference in low end torque with the system I had on my car. It was a 3" from the stock manifold, no cats, no resonator, with cutouts, to stock mufflers, and it sounded AWESOME! Loud, but no drone inside the cabin.
here is a vid to the exhaust sound....
http://www.youtube.com/watch?v=Q3zk6...e=channel_page
Hope this helps...
-Aleks
2015 S212
Hey buddy!
Hope this helps...
-Aleks
Hope this helps...
-Aleks
Mercedes
..... and I forgot that you are getting new mufflers too! It is going to be beastly loud after that....
check out my video when I had 3" piping and magnaflow mufflers...
http://www.youtube.com/watch?v=vHDG3...eature=channel
.... and yes it scares all of the children and old ladies when I drove by!![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
...or just go all out and get cutouts....
http://www.youtube.com/watch?v=_ImkO...eature=channel
I love exhausts!!!
I love exhausts!!!
Hey buddy!
Hope this helps...
-Aleks
Hope this helps...
-Aleks
in the above mentioned video that you posted did you incorporate a x pipe any where or was it just straight pipes till the muffler.
Hey buddy!
Hope this helps...
-Aleks
Hope this helps...
-Aleks
I know mine didn't, although it was not an E55. But again, an engine is an engine as the physic's are ALL the same.
Good luck with whatever you decide on
See yeah
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
The loss of tq is MAINLY on NA motors do to a lack of GOOD scavenging on the lower rpm side as the larger piping does not show as strong as a pulse. Since your motor is FI there really is NO worry here. As was mentioned above, the loss is negligable. Actually I would LOVE to see a before and after dyno showing this loss on any FI motor![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Good luck with whatever you decide on![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
See yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
See yeah
I really have NO clue how any FI motor could/would loose power on increasing the exhaust size? Espically with a stock cat that acts like a choke to begin with.
Mikey I know you are the king of the strip
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Look at this way, IF, and I use the word IF, you lost 30 lb/ft at 2000 rpm, how would this show up on the time slip as you are only at 2000 rpm for less than 1/10 of a second? And on the flip side the gain above 5000 rpm, lets say 10 HP for the sake of argument would MORE than make up for it, as you would be in this range for about 10 seconds.
Oh well, its safe to say that we will again agree to disagree.
Good luck and see yeah
X pipes suck, H pipes are the way to go. Coming from the cobra world, H's are way deeper and produce more low end tq. X's are raspier and produce more top end HP.
I can't wait for you guys to hear my new setup. After reading all the posts in this thread, I will go 3" from the primaries back with a H pipe instead of an x. I will also eliminate the bottle neck before the primary cat and basically run resonators as mufflers
Okay, so le't see them please.
, but I don't feel that a timeslip could/would show the SMALL loss, if any, in TQ. WAY too many variables as you are aweare of at the track. I think you will agree that you are NOT in the 2000-3000 rpm range for the entire 60' time, yes?
Good luck and see yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
if you really need me to scan and post timeslips tonight i will but i've got my launch and 1/4mile runs down cold and can run 60ft times within a tenth and et's within a few tenths every time. because of this, it's easy for me to understand when something isn't performing and opening up exhaust too much on my car just doesn't work.
i'm smart enough to know after driving several different amg's at famoso that each car does respond a bit differently to similar mods so this could be just the way my car behaves. i do know that there are people from this board that have noticed the same loss of tq after putting on a more free flowing exhaust such as the eisenman race set up.
