Fuel Injector Data
http://www.injectorcleaning.co.uk/flow.htm
unfortunately, still no show for SLR injector
in any case it seems that SLR fuel system is quite different than in 55K:
- 2 fuel pumps there (in parallel , just to double the pressure .. ) instead of 1 only
- 2 pressure regulators, instead of one
and ... even one thing which seems a "fuel cooler" (part n. 1404760217)
Assuming the SLR runs 80psi of static fuel pressure like the other v8 AMG cars, the injectors are then rated at 59.6 lb/hr(625cc/min).
If you want to figure out what your injectors will flow at a different pressure use this formula:
*Square root of* (new pressure/old pressure) *times* injector flow
Thank you !
. so finally we got the comparo: 462cc of SLR vs 412cc of 55K
ps: please post a link for those SLR data
The NA V8 AMG cars do not run 80PSI static fuel pressure
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Sorry. Definitely not 560cc, it was 516 or 517. I can check for you when I get home
That would make the injectors flow 519cc/min. Pretty close
I just got bored and called acting like a concerned SLR owner lol. The techy emailed me back with the info.
