Will MBUSA cover tires under warranty when they go bald for no reason?
So, being under the factory warranty, would MBUSA do anything about the stock continentals?
Thanks.
The first question they will ask is why you did not rotate the tires, so see they could have lasted 20,000 miles in theory.
If so it's probably an alignment issue. Uneven wear is usually caused by camber adjustment. You can tell if it's a toe issue if there is feathering on either edge of the tire. Feathering will feel like the rubber is actually being torn away unevenly on the edge of the contact patch.
Unless you can show a poor alignment caused this you are sol.
MB does not warranty tires unless you buy the tire warranty at the time of purchase.
It is not at all out of the ordinary (especially considering) it is a max performance summer tire. Your best bet is to call the tire manufacturer, or rather have the MB Dealership call them, DO NOT LET the dealership tell you they cannot warranty it and you have to go to an authorized Bridgestone dealership.
The dealership (and MBUSA) is automatically a Bridgestone/Continental/Michelin tire dealer, and can warranty them as well as they can warranty the entire vehicle.
Durable items are almost never covered.
Maybe you got hungry and ate the tires?
