Largest tire on E63 rear?
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
I will be buying a 07' E63 soon and i want to use the custom rims off my 01 E55 on this new car. they are 19x10 in the rear. i have 275's on them but they look small so i want to get a wider tire. can i fit a 295/35/19 on the rear of an E63 without rubbing issues???
any thoughts? appreciate it guys!
Aj
Aj
CLS55 AMG 030
its going to need to be a 30 side wall then it should fit no problem if the wheel has a aggressive offset. It will look a lot better with a 285 the 295 on a 10" wheel will make the tire cup around to fit the wheel. IMO
2008 E63, White/Black, P030
Aj
Aj
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
Aj
Aj
Stock is 265 35 18
I was thinking of 275 35 18
Anyone running 285 on the stock rim? And if so what tire profile are you running them on? 30's?
Thanks.
E63 P30, CL500 Sport
Yep
Super Moderator
Do you know which tire and profile he is using? It's time for me to get new tires and I was thinking of running a wider tire but didn't know you could push it that far.
Stock is 265 35 18
Thanks.
Stock is 265 35 18
Thanks.
2006 E55 (white); 2016 GL 550 (white)
thanks guys... so it looks like a 295 "might" fit. i have 275/35/18 right now and after i put them on, we'll see how it looks.
Getting the car friday "as of right now"...hopeing nothing changes. I might actually be keeping my older E55 as well until i sell it.
Aj
Aj
2015 S212
Tis true. The rear fits perfectly on the front and there you have a 265 on the front. The rear is an SL550 rim shaved 4mm on the insides to give a final 18X9.5 et37. 295s fit no problem.
Super Moderator
