Confused on power output and tuner claims. THought our cars had 493 but marketing....
Old May 14, 2009 | 09:29 PM
Bellevue_E55's Avatar
2006 Mercedes E55
reduced to 469HP.
So if we have 493HP like the S55 etc then why do some of the chip tuners show their stage one power being around 493 or lower..... what are they really doing on the HP side other than providing what the engine already has ?
Stock HP/TQ --- 493/516
Powerchips --- 487/536
Even the ones that go over 500hp.... seems like they get 24hp for free
Old May 14, 2009 | 09:37 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
STOCK HP is 469 (AT CRANK NOT REAR WHEEL)
So with a 18% drive train loss STOCK RWHP will be 384
the tuners usually post RWHP
Old May 14, 2009 | 09:45 PM
2006 Mercedes E55
So I watched a top gear that said we had about 500hp and I thought that was wrong as I had always read 469hp. So I searched mbworld and found a number of threads that say we have stock 493hp,
So are you saying that is incorrect and we really have 469 ?
Old May 14, 2009 | 09:46 PM
bassn_07's Avatar
2006 E55 AMG
I believe most get around 400-420 rwhp on a stock E55 when using a dynojet.
Old May 14, 2009 | 09:49 PM
bassn_07's Avatar
2006 E55 AMG
I beleive MB reduced the actual HP rating on the E55's as a marketing tool for the SL.
Old May 14, 2009 | 10:03 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
E has 469. First year of SL55 did too...they raised it to 493 due to price diff...aka marketing move.
about 400 at rear wheels...the auto box saps power but not as much as the Audis which have auto and AWD
Old May 14, 2009 | 10:11 PM
2006 Mercedes E55
So does the later SL have extra 24hp just based on tune and maybe exhaust
mhh its interesting reading the old threads where veryone swore we had 493... which maps up with 420 at wheels on dynojet
Old May 14, 2009 | 11:11 PM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
I buy the marketing part about the S/SL class. But isn't there something different about the Exhaust as well? Larger diameter?
jangy's Avatar
2015 S212
As mentioned, most stock E55s dyno at 400 - 420 rwhp as do all the 55ks. A solid stage 1 tune will get you almost 50rwhp. Best bang for the buck.
Old May 15, 2009 | 01:10 AM
InTheBenz0's Avatar
GLC 63 S AMG / Corvette C8 / Jaguar SVR
Stage one meaning tune + 172/180 pulley?
That considered stage 1?
Old May 15, 2009 | 01:22 AM
jangy's Avatar
2015 S212
Yes. It is the best bang you can get. I would do that and then cooling and see what else you want.
Old May 15, 2009 | 01:27 AM
bobgodd's Avatar
2004 E55
My thinking is along these lines as well. The power numbers were reduced for marketing, as well as actually reduced by detuning procedures.
Old May 15, 2009 | 01:34 AM
InTheBenz0's Avatar
Do the heat exchangers fit on the SL55? k&n drop ins, tune + pulley, cm030, and a h/e and ur set. I know there are fitment issues on the CL with the h/e... anyone you know, or sees this has a h/e on their sl55?
Old May 15, 2009 | 01:37 AM
jangy's Avatar
2015 S212
No, we have had many 55ks dyno'd side by side and never a difference. Some of the 55ks have different exhaust configurations, but only removal of a resonator, etc. I don't know about any of them being 3" piping.
The C63 was detuned by not having the TB open at WOT but that was different.
Old May 15, 2009 | 02:43 AM
bobgodd's Avatar
2004 E55
Drivers side intake tube? Fins in front of the intake openings?
This one I don't know about but didn't E55's have different throttle bodies than other 55K's?
I'm just sayin I think there is some detuning goin on. I know the drivers side of my exhaust was terribly pinched. And didn't VRUS say that the torque limitations in the software was lower than other AMG's?
Old May 15, 2009 | 09:33 AM
regor60's Avatar
06 E55 Black
Right, and this is all that counts and is very comparable to all the other S/C 55's
Old May 15, 2009 | 09:36 AM
regor60's Avatar
06 E55 Black
If there's detuning going on, then I guess the E makes MORE power at the engine than the others, given the same rear wheel hp...don't think so
Old May 15, 2009 | 02:13 PM
ENTIZY1's Avatar
05' E55 AMG
From what I understand the SL55 has more power due to the fact it has a larger throttle body stock from the factory, which gives it the additional 24 hp to the crank. The E55 has 469 hp and, it will put about 410 rwhp stock on a dynojet
Old May 15, 2009 | 02:36 PM
Fast55's Avatar
'06 E55, '05 SLK55, a few others
Umm, no. All 55K's are about the same. There are differences between models for sure, but they all make about the same power as Jangy stated. 410 RWHP is definitely NOT 469 crank HP, no MB drivetrain is that efficient. My '06 made 435 RWHP bone stock. It's obvious that equates to over 500 HP. SL's don't make more power than that stock.
Old May 15, 2009 | 03:47 PM
BenzoBoi's Avatar
Super Moderator
W221
You mean like this?
PM me fer details...
Old May 15, 2009 | 04:28 PM
ENTIZY1's Avatar
05' E55 AMG
so clk55 is the same as E55? SL do have a larger throttle body, but on the dyno doesnt make much of a difference
Old May 15, 2009 | 04:49 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
No, the CLK55 has the same engine but is not supercharged.
Old May 15, 2009 | 06:45 PM
BenzBoy12's Avatar
1988 535i 5 speed
+1, many have been dyno'd at well over 400 rwhp, and assuming 18% (although I thought it was closer to 20%) that's around 520 or so. They def. were under-rated as a marketing ploy, and I think the "big" 55k cars do make more than that even, based on the TB and a few other parts.
