Stages of the E55.
Old May 20, 2009 | 01:44 PM
blk06e55's Avatar
2006 E55 AMG
Stages of the E55.
This may be a newb question but... on the E55 what are the differences with the stages?
I see Stage 2 and Stage 3 and I have even seen Stage 5 E55.. What exactly are the differences between the stages? Thanks.
Old May 20, 2009 | 02:04 PM
V12Godspeed's Avatar
Your worst nightmare...
I would see it this way...
Stage 1- Pulley & Tune
Stage 2- Pulley, Tune, Headers & Heat Exchanger
Stage 3- Pulley, Headers, Tune, Heat Exchanger, 80 MM Throtle Body
Stage 4- Pulley, Headers, Tune, Heat Exchanger, 80 MM Throtle Body, Cams (well know for the famous Kleeman K4)
Stage 5- Pulley, Headers, Tune, Heat Exchanger, 80MM Throtle Body, Cams, Intake mods (Used by RennTech, they do CF Airbox and no Cams)
These days....they have variations of these mods by either putting long tube headers, 82Mm throtle body, meth injection, cold air intakes, Bigger Pulley, etc....but the core items are those. If I missed anything someone please chime in.
Old May 20, 2009 | 02:09 PM
daragez's Avatar
chevy
i agree!..that's right!...
Old May 20, 2009 | 02:12 PM
blk06e55's Avatar
2006 E55 AMG
Thanks guys!! is there anywhere that sells stage kits?
Old May 20, 2009 | 06:43 PM
taurran's Avatar
04 E55 AMG, 03 350z Track Built/Single Turbo
I would think that an intake mod would be lower on the list as it's an easy addition.
Has anyone figured out how to wire up a full stand alone EMS on these cars? Port/polish heads? Injectors? I'm also interested to hear at what level this blower is known to tap out at.
Don't mean to hijack or anything.
Old May 20, 2009 | 06:51 PM
Max.H's Avatar
E55
Not yet, It can be done. But would have to be used as a piggy back. You will lose all the features of the car other then running the engine pretty much.
From my understanding a 180ish mm pulley is the biggest you can physically put on the motor. The blower is good for now, it's more about keeping the charge temps cooler.
Old May 20, 2009 | 07:52 PM
Kevinw23michele's Avatar
I would think that exhaust should be in there somewhere.
Old May 20, 2009 | 08:38 PM
taurran's Avatar
Yeah, maybe I should have specified that the ECU would still need to control various functionality outside of timing/fuel/etc. I'm surprised no shops have adapted something like a Motec on an E55.
So the 180mm pulley is the largest pulley you can run and the blower still isn't blowing hot air? I'm interested to see how much that would net with all the aforementioned mods.
As far as exhaust, I would think long tubes, cutting out the mufflers and resonators (or replacing them with 3" straight-thru pieces) would be as about as crazy as you could go, but I'm not even sure the overall piping diameter it runs from the factory.
Old May 20, 2009 | 10:31 PM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
stages are nothing more then marketing terms
Old May 20, 2009 | 10:41 PM
taurran's Avatar
True, and internet terms for forum sigs.
Old May 21, 2009 | 03:16 AM
Andy0331's Avatar
'08 CL63
Yep & aside from Stage 1, many of the manufacturers are different. Some do airbox at "2", some do cams at "3", TB at "4", etc. I suppose you could break each piece down & call it a stage & end up with about 6 or 7 stages if you counted the cooling system & LSD; 8 if you got into the systems with a real intercooler upgrade.
I would venture to say most modded cars out there are a 3 of one form or another with ECU/Pulley, Headers, then cooling or TB for 3.
Old May 21, 2009 | 04:23 AM
blk06e55's Avatar
2006 E55 AMG
how much rwhp we talking on these E55's with 180 pulley, tune, long tubes, full exhaust, tb, cooling mods, intake with 2 filters?
Old May 21, 2009 | 09:21 AM
Agreed. But I bet you as soon as you say a Kleemann Stage 4 EVERYONE and their mothers now what the car has.. What I am trying to say is it already has been defined and it is somewhat of a Benchmark aisde from just being a marketting technique, Same goes for a Rennetch Stage V. It is just recently that we have started developing more the stages of the E55.
