Malfunction - "Electrical Consumers are turned off"
Anyone get this before? I get it all the time and I have a new huge 60lb battery. The AC keeps shutting off for periods of 2 to 30 minutes and I can't take it in the 90 degree heat, argg.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Sounds like it is time for you to replace the AUX battery under the hood, pretty important as it is the backup battery for your brakes (SBC) too.
1 Post
4 wheeled car.
Interesting. I get convinience features turned off when I blast my music at full blast for 30 minutes (while driving on the freeway). But I have an amp and two subs, so that's probably just draining all the juice.
your alternator is going bad. you will not get any other warning. No, you cannot use an obd 2 reader or star to find out. The car will continue to shutt of electrical consumers until finally the car will simply die. You may become stranded.
Ted
damn glad you knew this, I would have likely become stranded with no idea why, what do new alternators run on these cars?
Super Moderator
+1...I had that warning a while back and it ended up being the alternator.
Super Moderator
Well I don't have a bangin system or anything like that so I haven o idea. Mine prolly took a dump because of mileage. I figured it was about time...
SL600
Honestly, tho, I doubt that's your problem. MB alternators are oversized to begin with, you would have to go all xzibit on it before you would need more power. If all you did was add a set of subs and an amp, then odds are your alternator is crapping out.
Former Vendor of MBWorld
W211 E55
1 Post
4 wheeled car.
Do you know your total amperage draw for your amps? And have you installed any caps?
2003 E55 & 2014 GL550
Holy Cow! Ted Baldwin, what the heck you been up to you ya ole dog??
Just haven't seen that name in awhile.
Sorry if you've posting more lately, I've been off and on.
The man that took the G wagon bout as far as I've ever seen hp wise!
SL600
No headlight flicker. I think that happens only on non HIDs anyway...
No caps. I'm saying it's not crapping out b/c it only happens when I do it at MAX volume with bass up like crazy. Only happened..maybe 3 times. But everyday I blast my music on the freeway, and it's fine. I guess if it fails, it fails. No reason right now to pre-emptively replace the alternator.
I know the E55's have pretty beefy alternators, but I'm running two amps (1000RMS x 1 and a 250RMS x4) and with volume cranked my dash lights do flicker at night. I would get a cap, but I mostly listen between 1/3 and 2/3 volume and there are 0 issues there.
