Per the Godfather requested, We made this carbon grill ~
1 Post
4 wheeled car.
Who is that Godfather guy??? That grill looks sick as is!! What is confusing people is that fact that the stock grill has stuff between the slats, that's why these look so spaced out. Personally, I LOVE IT! I think it has to be shown on a car for people to truly appreciate it.
Ivan, send it over
Ivan, send it over
1 Post
4 wheeled car.
Ok after looking at it in more detail, I can see how if the spacing is reduced it may look a bit better, but on the same token, I think it may be too busy if too many slats are present.
The pictures taken obviously had a flash on which shows behind the clear very clear/light, as opposed to dark as it should be, which would then blend in the grill a bit more and make it look less airy. I made a photoshop of the grill on my car when it was bone stock (I made a mockup flat hood badge), so you can get the idea with correct lighting how it may look.
Sup dude. First off love the whip. Here is mine, looks real similar. Love ur wheels
http://www.6speedonline.com/forums/m...ks-lucent.html
The grill i think
will good, might need a little revision, got to see it in person i guess, the pictures do make it look weird and stand out in a bad way. I think its because of the lighting behind the grill also.
Here tho however i do see a problem as like stated above from another member. It looks a little bent, either the mold or the way it was dried, or formed or what ever. What do you think?
The thing i did in photoshop kinda makes you not notice what i am attempting to point out, look at the original picture posted
The grill i think
#32
http://img23.imageshack.us/img23/2765/img4184o.jpg
can u send that to me in a high def ?
jdj27x@gmail.com
jdj27x@gmail.com
#35
1 Post
4 wheeled car.
jdj27x@gmail.com
jdj27x@gmail.com
That's what I'm saying!
#37
SPONSOR
Real picture on silver W211 and problem solved
I got the sample yesterday and installed it on our W211 wagon
all the questions and problems are just the pictures been taken, all the problems solved by turning off the flash light! check these pictures out and let us know what you think!
#46
