How much cold air do you feel through the seats?
Old May 28, 2009 | 03:26 PM
blk07bruins63's Avatar
2007 E63 AMG, 2012 F250 4x4
Finally drove my car in heat last Sunday and turned on the seat fans. I had the rear Temp. setting @ 67*. The seats were cool to the touch but I'm not sure if we (wife & I) should feel a strong flow of air or not? I turned the settings down for the seats and could not tell a difference. Any thoughts?
Old May 28, 2009 | 04:04 PM
t-bone's Avatar
2004 E55
This has been addressed before. The seats don't blow air. The air is drawn into the seat. So you can't really fell the air that well.
https://mbworld.org/forums/w211-amg/...ted-seats.html
Old May 28, 2009 | 04:06 PM
Benz-O-Rama's Avatar
They're not cooled seats, they're ventilated. They're not meant to cool you, only to keep your back and butt dry in hot weather.
Old May 28, 2009 | 04:16 PM
Thanks t-bone & Benzo! I read on this forum somewhere that if you turn the rear temps down the seats will be cooler. That would not be the case as you guys have described. I thought I felt the air being drawn to the seat but wasn't real sure.
Old May 28, 2009 | 04:19 PM
t-bone's Avatar
2004 E55
If you look on the back of the seats, you will see the vents where the air comes out.
Old May 28, 2009 | 04:26 PM
I saw the vents but assumed they drew the air in.... Just the opposite.
Old May 28, 2009 | 04:29 PM
KV3BLUE's Avatar
2008 E63, White/Black, P030
Since you guys are talking about seats. How does the adjustment buttons work for adjusting the seats side bolsters and back rest. I adjust those buttons right infront of the seats thigh area, but nothing happens on the driver and pass side.
Old May 28, 2009 | 04:38 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Middle rocker is lumbar for either lower or upper back (push down for lower and up for upper) Plus and minus button is how much lumbar (watch out, it can be like Mt. Everest) Side long button is the bolsters in and out. Bottom rocker is thigh support.
Old May 28, 2009 | 04:58 PM
KV3BLUE's Avatar
Thanks. I will try again, but as I recalled nothing happend last time, hmm
Old May 28, 2009 | 05:01 PM
220S's Avatar
Ignition on? I think it has to be on(?) Can't remember.
