Thoughts on Blackfire Polish
However, I had one heckuva time trying to polish the fine swirls and towling marks out of my black car with Zaino Paint Cleaner. The Z5 really "hid" alot of the imperfections, but they gradually re-surfaced over time. So, this spring I decided to try Blackfire. The info (hype?) regarding the ultra-hard ceramic clear coats on newer Benz cars made sense, and Blackfire ceramic clear polish seemed ot be the answer.
I did the top to bottom routine last week with Blackfire and was initially impressed. The car looked amazing under a non-flourescent light bulb. But under a flourescent light at the gas station at night or in bright sunlight, the paint looked just a spider-webbed as before.
I spent all weekend pouring over MB posts as well as every car detailing site online looking for the miracle potion. Everything I read pointed right at Blackfire's "new" ceramic polish.
I went back out to the garage yesterday and re-did the only trunk lid: cleaned, clayed, and polished. However, this time I set the speed on my random orbital up to the 4-5 range and got brave and really put some pressure behind the polisher. I made really steady, even passes at the higher speed with more pressure and did the trunk 3 complete times, wiping off the residue in between rounds and re-polishing with a small amount of fresh polish eash time.
After the 3rd round, the trunk lid was absolutely swirl free - like glass - even under the flourescent worklight in my garage. No comparison at all to the rest of the car. I topped it off with a generous coat of Blackfire "Wet Diamond" sealant and it was unbelievable. I know what I'm going to be doing ALL WEEKEND LONG next week!!!
So, the moral of the story is, the ceramic clear coat on our cars is REALLY hard. As long as you are using a random orbital - not a direct drive polisher - and using the proper foam pad and product, you won't damage the finish to crank up the rpms and really lean into it a bit.
FYI
FYI
1) If you are using a porter cable polisher its basically harmless for your paint. You could sit on it and it wont burn the paint (though I would not try that). It has so little actual circular rotation that it is very slow to cut the paint.
2) I would recommend a Flex polisher as it has far more power than a Porter Cable. It takes a bit more skill but it is still very safe with all but the toughest polishes and pads. It will make your swirl mark removal far easier and quicker.
3) I would recommend the full like of Menzerna Polishes and then the BlackFire Wet Diamond Sealant. The polishes used by Blackfire are just Menzerna re-bottled. The full line of Menzerna polishes covers a better grouping of paint flaws. They are second to none. This "new" ceramic polish came out several years ago (2004-2005) and there was a slight revision for less dusting last year. The polish for ceramic paint from blackfire is just P106FF from Menzerna. I have both and its the same stuff.
4) For a black E55 with minor to moderate swirl markings you really only need the 106FA Polish from Menzerna. You can also get the P085RD if you want the finest polish for maximum surface perfection as this is the best finishing polish for black paint. Follow up with Wet Diamond for a perfect finish. A more swirled or damaged paint will require a power finish S203 or Super Intensive Polish.
I would add that you might want to use Lake country foam pads. try orange for cutting and white for final polish. and maybe gray/black for wax/sealant/glaze.
good luck and rtemember try to take as little paint as possible. Doing test panel and inspecting your work continuously under a good source of light.
PDC
PDC
A PC polisher (ones sold from griots and say any tool store are the same) is more of a jiggler in motion. I has some circular motion but the minute you put pressure on the polisher the circular motion virtually stops (thats what makes it so safe for beginners) A flex has what is known as forced rotation. So while it still bobbles about in a random orbit, it also has a forced circular rotation giving it that additional CUTTING power.
Say a PC is a 3-4 on a scale of 1-10 in cutting power. A flex is about a 7-8 and a motabo full rotary is a 10.
I went with the Flex because while experienced I am not a pro with a true circular polisher. I will have one soon but I wanted to go step by step. I have yet to find a job the flex could not do but it will take more time than a full rotary polisher.
And as stated above, for sure get the full line of pads from lake county. The above poster was spot on with the pad selection. I have the yellow, orange, green, white, black and red pads from lake county (get say 2 or maybe 3 of each - 3 of the white and orange as those will be use the most frequently). The black was now replaced with a gold pad and you can also get wool pads for serious cutting power.
Keep the PC for applying sealant, get the flex for most polishing and then later get a true rotary from motabo for the really marred surfaces.
Link: This link is a link to the site for DetailersDomain.com Phil, the owner, is a fantastic vendor and he will never miss a beat. I have been beyond happy with his service and his pricing is the best on the net for everything. He will respond to your questions quickly and is always glad to help. Unlike some sites, Phil actually details cars instead of just trying to push product. He knows first hand about what he sells and will not lead you astray. His pads have a different coloring system for the different levels of cutting power when compared to say properautocare.com The quality is the same he just has a different system going. I would buy everything from him from here on out.
http://www.detailersdomain.com/index...ROD&ProdID=246
If you have swirls that keep coming back and Z-5 won't cut it, it may be time to clay bar and start with Z-PC. I've had good results with it.
Zaino is great for protection as it really does last quite a while. Trouble is it has a very plastic like finish on darker finishes. It will be very reflective but it will lack any depth. Its could be considered the inverse of a carnauba wax product in that carnauba wax's create wonderful depth and little protection.
The current generation of synthetic products have the protection of say zaino and some of the depth of the Carnauba wax. Menzerna FMJ was the first to offer wonderful depth with lasting protection. Then Blackfire came out with the wet diamond product and it has better protection and very similar depth and clarity.
I used to be a serious zaino lover but after branching out I have really found products that surpass it in all ways. On a silver car zaino is great but on a black car its pretty boring looking imho.
Thanks agan to those with first hand experience for all your info and help!
