High Flow Cats.....
I have Vadim's shorty headers, mid-section. and 200 cell race cats. I have the race cats where the primaries went and no secondary. I'm also running his x-pipe and kept the resonator. This setup definietly makes power and let's the car breathe. With that said there's no replacement for the power long tubes give, at least properly tuned ones. JMO.
Former Vendor of MBWorld
C55,SL55,C63
Alan, I'm with you on the properly tuned long tubes. After some research I just found out that every header available for my car that has a merge collector design has the wrong firing order, For me this explains alot of question I has about loss of power up top due to the headers inability to scavenge. A proper long tube header should fire in a clockwise or counter-clockwise pattern pending how you look at it. Not in a random diagonal cross pattern.
...After some research I just found out that every header available for my car that has a merge collector design has the wrong firing order, For me this explains alot of question I has about loss of power up top due to the headers inability to scavenge. A proper long tube header should fire in a clockwise or counter-clockwise pattern pending how you look at it. Not in a random diagonal cross pattern.
E55 then E63, now back to an E55
E63.... & Thx
What would happen if I replaced my primary cats w these ?
(Either Random Tech or the ones from Victor/Vadim)
Factory piping until X-pipe in place of resonator and Meisterschaft axle-back....
Emissions don't matter - power, sound, gas mileage -- what do they do ?
https://mbworld.org/forums/w211-amg/...akes-best.html
C55,SL55,C63
Most companies buy their cat cores from the same supplier and then slap their name on it. Its whats on the inside that counts. Its really comes down to size, cells, and construction. Your going to need to find out the type of substrate being used compaired to cell count and over all size.
You can get a 200 Cell cat but if its to long that it can end up hurting you. Or you can get a 300 cell cat, but if its to short it can also hurt you. Cats are complicated. thats what alot of company's base them on engine size to make the process a bit easier.
If the OP PM's me I can get them a set of nice hiflow cats and a far less price than any name brand out there and have them be just as good. If you go with Random Technology cats expect to pay $600 for a set. That way to much.
