Heat Exchanger Questions
Subscribe
Aug 3, 2009 | 06:24 PM
hey guys it took me a while to figure things out but im now in the final stretch for my HE upgrade. i went to my local shop, Advance Motors, a few times and we took measurements and found a size that should fit in the front of my car. the biggest we felt safe going with is 30x6x3.5 inches (with end tanks). i then asked bell intercoolers to make a dual pass liquid to air HE with tube and fin design that would match those dimensions.
here are some pics of the final product which i picked up today.
measurements came out to be 30x6x3.25 inches with the end tanks being about 3.56" thick.
i sure hope that this fits nicely up there, brackets will still need to made and welded on when advance begins the install.
i have a johnson CM30 and a bmw power steering reservoir on the way and when i bring it in to get installed along with vadim's mid-section kit ill post up more shots.
in the meantime my car is going in tomorrow for an 82mm TB install (made by vadim) and im pretty excited about that. i hope it will mate with my VRP CF airbox!
here are some pics of the HE:
Reply 0
Aug 3, 2009 | 09:06 PM
I used the new shelby cobra take off intercooler on mine. Made a couple brackets and never had to remove the bumper for the install. Other cars may vary
http://cgi.ebay.com/ebaymotors/SALEE...=p4506.c0.m245
You can pick them up on ebay for 100 bucks , if you look hard. These are Garrett heat exchangers (about 30 ounces) and match our under blower intercoolers . Yes we have Garrett's under blower intercoolers on our German AMG`s and they are made in mexico..
Reply 0
Aug 4, 2009 | 03:18 AM
nice man, i hope theres a way i can slap this in without removing the bumper as well!
Reply 0
Aug 4, 2009 | 08:04 AM
Quote: hey guys it took me a while to figure things out but im now in the final stretch for my HE upgrade. i went to my local shop, Advance Motors, a few times and we took measurements and found a size that should fit in the front of my car. the biggest we felt safe going with is 30x6x3.5 inches (with end tanks). i then asked bell intercoolers to make a dual pass liquid to air HE with tube and fin design that would match those dimensions.
Let your shop know i will be the second to purchase this kit when you guys are done all the R&D. I like your initiative. We should put our heads together and make stuff for this platform since none of the vendors really want to step up to the plate I can send over a deposit right now.
Reply 0
Aug 4, 2009 | 11:37 PM
ill definitely keep u posted on that.
still have to test fit and make brackets and all that.
Reply 0
Aug 5, 2009 | 03:05 AM
Quote: I used the new shelby cobra take off intercooler on mine. Made a couple brackets and never had to remove the bumper for the install. Other cars may vary
can you tell what size is this
and didn't you find anything with fins positioned vertically instead of horizontal ?
Reply 0
Aug 5, 2009 | 07:43 AM
  #32
Horizontal fins will cool better then the vertical fins because there will be more passages and fins...
Reply 0
Aug 5, 2009 | 07:53 AM
  #33
Quote: Horizontal fins will cool better then the vertical fins because there will be more passages and fins...
sorry but I read it that passages are more in number if vertical
and would not want anything thicker than stock to avoid heat be passed on
Reply 0
Explore
Aug 5, 2009 | 08:37 AM
  #34
Sorry, I wrote that incorrectly. Vertical will have more passages and and will flow better but not cool as well. Horizontal will flow less but cool better because of the longer passages. Too early for this stuff
Seems as if the vertical is better for lower boost and the horizontal is better for higher boost.
Reply 0
Aug 5, 2009 | 09:11 AM
  #35
Has anyone tried any of the aftermarket ones they sell for the Cobras and GT500's?
Reply 0
Aug 5, 2009 | 11:43 AM
  #36
The E class can use a wider and larger H/E. Say 30" wide but also must remove the bumper to instal. I do not know how much room is in the CLS or SL front grill. On the CL, I only had to remove the front lower screen and it fit right in. There were two bolts places, so no holes were drilled or any other major modification. The new Cobra H/E is 26.75 wide, 2" deep and I think 6" wide. This was the absolute largest H/E that would fit on my car. Oh yeah, I measures the added water capacity at 30 ounces. (feel free to convert to metric)
Please note: I only recommend using this H/E as an addition to your stock H/E cooler and not in place of. I run two H/E`s and the results are perefect for my set up. The smaller, thinner H/E also does not block to much air flow form my oil cooler or radiator.
Reply 0
Aug 5, 2009 | 12:19 PM
  #37
Quote: The E class can use a wider and larger H/E. Say 30" wide but also must remove the bumper to instal. I do not know how much room is in the CLS or SL front grill. On the CL, I only had to remove the front lower screen and it fit right in. There were two bolts places, so no holes were drilled or any other major modification. The new Cobra H/E is 26.75 wide, 2" deep and I think 6" wide. This was the absolute largest H/E that would fit on my car. Oh yeah, I measures the added water capacity at 30 ounces. (feel free to convert to metric)
thanks,
it seems similar enough in size to our stock unit ... so if you added it to your stock unit I guess those 30 ounces added capacity, less than 1 liter, means it is its own total capacity
as JikJak said, for CLS we have:
By looking underneath the car and taking several measurements it seems that the OEM Behr unit measures about 28" x 5" x 2.25" (end tank to end tank).
the space available for an OEM HE replacement and the dimensions im going to go with are 30" x 6" c 3.5" (end tank to end tank). theres almost enough space in there to fit 2 OEM units! the height is limited by the oem oil cooler, otherwise it would be possible to go over 6".
afaik CLS has a lot of free room along depth and maybe fitting 2 HEs in parallel
is a good idea but IMHO the front one should be smaller and some ducts for flowing air to the second one should be designed.
I will deal with this thing next on, if I can first solve the main issue of top IC
but in principle I would check for free room to the left and right side from the stock location for adding some unit ...
Reply 0
Aug 5, 2009 | 04:34 PM
  #38
Quote: thanks,
it seems similar enough in size to our stock unit ... so if you added it to your stock unit I guess those 30 ounces added capacity, less than 1 liter, means it is its own total capacity...
My stock oil cooler is in the same place as the E55 H/E and looks simulair. I assume the E is also the same as the CLS and maybe the SL the same as the E? My stock H/E is about the same size as the radiator and located behind it. It is only 1" wide and not as thick as the radiator. The new H/E is added in line of the H/E system and Adds an EXTRA 30 ounces of coolant. This lowered my average IAT from 30-40 Deg over ambient to around 10-15 degress over ambient in the hot Texas heat. (90 deg. to 103 deg.)
Just a guess but it seems two seperate H/E`s with same total capacity as one, cools better than one H/E that is just thicker. In other words, I would rather add an auxillary cooler , have more frontal surface area, than have one thick cooler.
Been a while since I calculated this system but I think I can run 16 seconds of boost, before the water makes one circulation. Then it only takes 6-8 seconds to recover.. I am very happy with that! Stock was like 40 seconds, just to recover to 30 deg over ambient.
Reply 0
Aug 5, 2009 | 05:40 PM
  #39
if "in line" means in series, then you should get much better results fitting it in parallel. according to literature on this subject.
very correct, according to literature
Reply 0
Sep 5, 2009 | 04:56 AM
  #40
well i finally had my larger HE installed today.
im very happy that the local shop that i frequent, advance motors, did a great job with the install. they fabricated me some nice brackets to mount the HE and were able to make use of the oem brackets to mount the oil cooler underneath it. they were also responsible for helping me take the initial measurements so that i could have the HE made. they are also going to see if they can hook up some sort of temperature sensor to get the pump to turn on at the temp that it is set at.
anyways here are a few pics. ill take some better shots of it installed on another day.
Reply 0
Sep 5, 2009 | 05:16 AM
  #41
Nice, you may want to just wire the pump to turn on with ignition
Reply 0
Sep 5, 2009 | 05:21 AM
  #42
by doing that will the pump be running whenever the car is on?
would that cause the pump to wear out fast since its always working?
Reply 0
Sep 5, 2009 | 08:29 AM
  #43
nice pics.
I have also wired my ic pump to the accessory.
Reply 0
Sep 5, 2009 | 08:37 AM
  #44
Quote: by doing that will the pump be running whenever the car is on?
each pump has a set working life in hours. so yes the working life of the pump will be over sooner when it is wired to the accessory.
Reply 0
Sep 5, 2009 | 08:38 AM
  #45
From what I've heard, the pump is on pretty much any time the car is running, not just under boost. The advantage of the hardwire would be the ability to run the pump when the engine is off, in the staging lanes for instance. However, without a fan pulling air through the HE I don't think just circulating water will do much.
Reply 0
Sep 5, 2009 | 08:46 AM
  #46
a few thoughts. the i/c pump comes on at 2000 rpm and stays on while the engine is running. unless you want to flow the coolant while the engine is off ie: cooldown after racing , its not needed. also it appears you have enough room to install a larger h/e in front of the radiator. thicker isnt better ,larger area is here some fotos of the h/e i hade made for my slk32 . cost aprox 350$ with my cm30 the flow rate 4.7 gpm! its a dual pass h/e
also if you separate the coolant system from the intercooler system the temps of the i/c fluid will be reduced significantly. by not allowing the 190 * engine coolant thru the i/c temps are reduced. hope this helps
btw my h/e is 26" wide 16" tall and 1" thick at the cores, 1.75 at the tanks
Reply 0
Sep 5, 2009 | 09:56 AM
  #47
Yes the pump will be running whenever the car is on. Helps keep it cooler. The colder it is, the lower your IATs and the more power
Yes.
Quote: From what I've heard, the pump is on pretty much any time the car is running, not just under boost. The advantage of the hardwire would be the ability to run the pump when the engine is off, in the staging lanes for instance. However, without a fan pulling air through the HE I don't think just circulating water will do much.
Thats why you put ice on the charger while its sitting with the pump on
Reply 0
Sep 5, 2009 | 02:46 PM
  #48
so what is the lifespan of the pump?
hmm maybe i should have it hooked to the accessory then hehe
Reply 0
Sep 5, 2009 | 03:06 PM
  #49
there's no need to rewire the pump...under normal conditions it's on all the time with exception of cold start mode.
Reply 0
Sep 5, 2009 | 05:22 PM
  #50
ok thanks, i can just leave it alone! even better hehe
Reply 0
