Heat Exchanger Questions
Old 06-23-2009, 11:33 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
I would like to have a larger OEM replacement HE made for my car. There doesnt seem to be one specifically made for the CLS so im trying to get one made on my own.
By looking underneath the car and taking several measurements it seems that the OEM Behr unit measures about 28" x 5" x 2.25" (end tank to end tank).
the space available for an OEM HE replacement and the dimensions im going to go with are 30" x 6" c 3.5" (end tank to end tank). theres almost enough space in there to fit 2 OEM units! the height is limited by the oem oil cooler, otherwise it would be possible to go over 6".
i have a few questions so that i can have this made properly and i hope some of you can help me out.
1) what type of fittings (pipe thread, AN fittings or hose barbs) should i be using, and also what size the fittings should be?
2) im hoping to just plug in the stock hoses and fittings to the larger unit. what size and type are the OEM fittings and hoses?
3) what should the end tanks look like or be shaped like? (pics would be great)
i will also get a higher flow cooling pump (not sure which one yet, but something bigger than a CM30) and also split the cooling circuit. either have a reservoir custom made (not much room in the bay) or just use the BMW power steering fluid reservoir (or something along those lines).
here is the place that i have contacted.
http://www.bellintercoolers.com/index.html
thanks for the help guys, once i get this done i can get a 180mm pulley and a custom tune!
Old 06-23-2009, 11:46 AM
Former Vendor of MBWorld
MBH motorsports's Avatar
C63, SL55, E55, CLS55, ML63, C55
We have one already completed for the CLS55 its a monster. The CLS55 has so much room for a nice size HE. My brother, Member name "Hoolamonster" will be installing it on his CLS55 very soon. I can get you a picture of it today. PM me. I can have one soon for yeah
Old 06-23-2009, 12:26 PM
Full Throttle's Avatar
CLS55 AMG
I am interested as well please post pic's when available.
Old 06-23-2009, 12:49 PM
i will have pics up today for ya
Have you guys thought about running your supercharger/intercooling system independently?
Old 06-23-2009, 01:50 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
can u elaborate on that?
Old 06-23-2009, 02:14 PM
The CLS55's H/E has the fittings (In and out) on the same side. In order to keep the stock location for the hoses some tricky fab would have to be done inside the H/E. You want the H/E to flow in a "S" or snake like pattern on a larger H/E.
mounting on fitting on the top and the other in the stock location would be the easiest way. You would just have to run a small hose extention. I will get you guys a pic today of the H/E I got working for you guys with CLS55's
We have a bone stock CLS55 we are putting this in. After the install we will monitor IAT's on the dyno and street. and base them over the stock H/E IAT's.
Honestly there is so much room in the CLS55 you could have a fatty H/E with electric fans too. Just and Idea.
Old 06-23-2009, 02:15 PM
CLS55 AMG
Now we are talking!!!
Old 06-23-2009, 02:35 PM
I'm going to be doing some dyno runs with my car today with the new headers. But inbetween runs I will get some good pics of the CLS55 H/E.. Funny I happen to have my 7.3mpix camera in my pocket today so no crappy cellphone pics.
PM "hoolamonster" He is my younger brother, tell him he needs to do the CLS55 community a service and install this huge heat exchanger.
Old 06-23-2009, 04:00 PM
OUTCAST's Avatar
SLK55AMG, SL600
Man that sounds nice.
Old 06-24-2009, 11:41 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
so does anyone happen to know any of the answers to my questions?
Old 06-24-2009, 11:54 AM
I got pics for yeah but they are at the shop. I will get them up today. The end caps are just slip on hose fittings that are held on by a clamp.
The bigger the HE you use it should be sectioned so the fluid snakes down the HE. so there should be some dividers in a larger HE so make this happen. Its a much better way then to just have two big end caps that act like reservoir. I will do a cool picture in Photoshop of what you are looking for today.
Old 06-24-2009, 12:48 PM
Super Moderator
BenzoBoi's Avatar
W221
PM sent...
Old 06-24-2009, 01:01 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
thanks, that would be great.
so basically u just use regular pipe thread fittings and no need for AN fittings?
also what size are the fittings used on the oem unit?
ill try and find out how the Bell HE is sectioned off.
theres some info on their HE on this link
http://www.bellintercoolers.com/pages/LAMain.html
they called me yesterday and informed me that they can make the size i want and that it would take a couple weeks to do so. i want to wait and see yours as well. please post those pics.
Old 06-24-2009, 02:55 PM
CLS55 AMG
Jik please keep me in the loop if you go this route of if the other vendor drops the ball.
Old 06-24-2009, 03:38 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
will do!
Old 06-26-2009, 05:34 PM
CLS55 AMG
Oh well so much for the pictures.
Old 06-29-2009, 06:50 PM
jikjak's Avatar
CLS55 AMG & RRS S/C
hopefully they get posted soon!
Old 06-29-2009, 07:23 PM
Super Moderator
BenzoBoi's Avatar
W221
Here are 3 pics from HYEVON Motors ' set up.
Old 06-30-2009, 04:13 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
wow, that looks good!
thanks for posting!
Old 06-30-2009, 05:55 PM
CLS55 AMG
Price and availability???
Old 06-30-2009, 06:29 PM
Super Moderator
BenzoBoi's Avatar
W221
PM Sent...
Old 07-22-2009, 03:34 AM
Ohbev's Avatar
E55 AMG Kompressor
e55 HE
Benzo bai pm me the price and give me a there web site if you have it
Old 07-23-2009, 12:32 AM
AZIPOD's Avatar
W211,E90,E66,E39,E38,NSX,Z32-TT
On a side note, what do you guys think about removing the mesh grille which "hides" the heat-exchanger. Buy making it more visible, do you think it will make the car look more aggressive?
Old 07-23-2009, 02:26 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
i dont think it would look too good if u removed the mesh.
it already looks mean when u can see it peeking out from under there.
the mesh also helps to protect your HE from rock damage as well.
Old 07-23-2009, 02:51 AM
Super Moderator
BenzoBoi's Avatar
W221
I vote no.
Quick Reply: Heat Exchanger Questions
