I pod amplifier Install
So install was simple
Here is the part
So I found the control part for the kit undr the glove box (above the pass. feet area) looking up from the floor you can see 2 torx head screws, take those out and wiggle the pannel down.
Now unplug the cable and plug in the amp and postionit so you can replace the panel
Replace the panel into its spot tighten the screws and your done. should take less than 20 min start to finnish.
https://mbworld.org/forums/w211-amg/...d-install.html
Page down to post #25
If they question the price tell them its a part to fix a mistake mercedes made. That seemed to end the question about why its so cheep.
Strange thing, I asked them how much to install it and they said $67? Maybe the part is free, but they charge that for the labor, whether they install it or not? Does this thing really make a difference?
1. You have incorrect part
2. MB may have changed design so you don't plug in newer model into the AMP which is not needed (speculating here).
