TPMS Question
Old Jul 1, 2009 | 08:09 PM
Objectionable's Avatar
E55 AMG
TPMS Question
I saw it asked in another thread, but I don't believe it was answered:
If you don't have TPMS sensors on your wheels, is a warning light displayed on the dash?
Old Jul 1, 2009 | 08:15 PM
bobgodd's Avatar
2004 E55
If your car thinks you're supposed to have them then yes.
Old Jul 1, 2009 | 08:19 PM
E55 AMG
Dang it, I suppose it was wishful thinking to hope that wasn't the case. I really want some 19" p30 SL65 wheels. Those cost plenty, without adding extra expense for TPMS.
Thanks.
Old Jul 1, 2009 | 08:43 PM
bobgodd's Avatar
2004 E55
If you have TPM sensors right now then you should be able to swap them on to the new wheels. If you don't currently have TPM sensors, then you will not get an error code.
Old Jul 16, 2009 | 10:01 AM
P ONE's Avatar
2001 CL600
TPMS add
My car has TPMS in the system (it shows up in the display), but I dont have the sensors. Can I simply add the sensors to the wheels and it will detect them? If I can, should I stick with OEM only or could I go with one of the aftermarket sets?
Old Jul 16, 2009 | 12:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
u can use aftermarket sensors (from tirerack) but i think it needs to be version coded?
Old Jul 16, 2009 | 01:39 PM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
few things about tpms
- if you have tpms and you get wheels without it, the light will come on
- you can have it coded out with Star. i have this done on my car
- i do not recommend swapping tpms sensors because they can easily get slightly damaged and leak air slowly. this is pretty common
