ASP 180mm Pulley anyone?
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Brand new in the box 180mm ASP pulleys. Kits all come with new belt and water pump pulley
Will fit, W211 E55, W215 CL55, W219 CLS55, W220 S55, R230 SL55
$800 plus shipping give us a call today!
to a great sponsor and product. I just recently had one installed and and in combination of a few other things my car is performing well. This thing really gets the SC whining!
So is this the latest ASP unit?
The older one was a 175mm right?
I would think with a 180mm unit you would need headers to keep pressure/heat in check?
PLATINUM SPONSOR
I measured the first pulley at 177.6 as I recall and do not have heat issues or pressure issues with the newer (Sept.08) 180mm.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
