Logged boost today, Normal?
Old Jul 23, 2009 | 04:48 AM
sneakyneon's Avatar
Bicycle
I did some logging and trying to see if my boost level is right and if the belt is slipping, I'm still not sure? The 2 screen shots are of the same pull but one has tags to help see the boost numbers. The pull is only 4 to 5 sec long.
The car has a asp 178 pully, 3 inch high flow exhaust.
Old Jul 23, 2009 | 06:52 AM
OJPAMG's Avatar
2005 E55 AMG
where do you get this software from?
edit.I found hte software but where or how can i get athe comm cable to use it?
Old Jul 23, 2009 | 08:51 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
did you use a stock map sensor or an added one from Zeitronix?
Old Jul 23, 2009 | 09:07 AM
slownrusty's Avatar
'06 E55 K2
Stock boost is 13.1psi and I see a peak of 14.3psi at about 5100rpm. What does a 178mm pulley supposed to yield? It appears there is slippage as your boost is up and down even though the rpms are climbing.
Yasin
Old Jul 23, 2009 | 09:48 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You boost levels are right on for a 178mm pulley. Now there may be some slippage but for sure there is no boost leak.
Stock boost is 11.8 from what I remember.
Old Jul 23, 2009 | 09:57 AM
shardul's Avatar
Old Jul 23, 2009 | 12:31 PM
sneakyneon's Avatar
Bicycle
You need the whole thing not just a cable, Its all available from from zeitronix.
Old Jul 23, 2009 | 04:35 PM
sneakyneon's Avatar
Bicycle
Its the zeitronix 50 psi map sensor.
Old Jul 23, 2009 | 04:43 PM
sneakyneon's Avatar
Bicycle
Its just hard for me to say if the jagged lines are normal? I think the boost sensor is reads very accurate and the sample rate is high so its seeing every little thing, Ive never used this boost sensor on another car to compare too. I bet an anolog gauge would look smoother.
Old Jul 23, 2009 | 04:49 PM
jturkel's Avatar
02 C32 AMG
how can you or how would you tell where/if/when belt slip is occurring by looking at the these logs (sorry, im a newb to data logging)?
Old Jul 23, 2009 | 05:11 PM
sneakyneon's Avatar
Bicycle
You will see varying boost levels, The boost is dependent of the belt spininng the supercharger, so when it slips it changes how much boost you see.
Has anyone had a supercharger clutch slip? Or is it just harsh engagement? Mine has the typical harsh engagement but I can live with it if its not costing me performance.
Old Jul 23, 2009 | 11:04 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Nice to have the Zeitronix’s capabilities with which to log. Your boost versus rpm curve is not at all unusual.
The supercharger’s electromagnetic pulley coupling may be heading south, but it’s almost always a off or on device until its bearing fails. Belt slip can be a factor owing to the substantial power required to turn it at WOT.
Some have experienced marginal boost and performance improvements from belt wrap kits.
A far more likely occurrence is intervention from the bypass valve IMHO. A cursory glance at a stock vs. upgraded crank pulley dyno run dramatically demonstrates the phenomena.
Almost certain that clutch or belt slip were not a factor with Mr. Frost's. :)
image credit Marcus Frost
Old Jul 24, 2009 | 05:24 AM
sneakyneon's Avatar
Bicycle
What was the fix for this?
Old Jul 24, 2009 | 07:04 AM
OJPAMG's Avatar
2005 E55 AMG
Can someone send me a link to purchase this setup? I see the free software but dont see the communication setup.
Old Jul 24, 2009 | 01:30 PM
TopGun32's Avatar
tuning.. controls the bypass valve.
do you have a tune?
also, did you look at your timing.. it should be all over the place. Once the car is tuning.. the timing goes back to normal.
Old Jul 24, 2009 | 11:37 PM
sneakyneon's Avatar
Bicycle
http://www.zeitronix.com/
basic kit is 279.00 then you just buy the add on that you want. they sell it all. Mine is the full meal with egt, boost, and warnning light. Its a great kit.
Old Jul 24, 2009 | 11:38 PM
sneakyneon's Avatar
Bicycle
do you have a tune?
No tune...yet. I think I'm going to wait for some of the hand held stuff to come out
