Oil vapor from -oil filler cap?
Have not looked at this in years, so just checking.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Once the rings and cylinder walls have become friendly with each other, figure on no more than one or two CFM of positive displacement at idle. The ‘mist’ you’re witnessing at the filler cap is normal discharge from under our cam/valve cover.
If you haven’t already done so, fit a catch can in the PCV system to help keep spent crankcase hydrocarbons from migrating into the intake tract.
