CLS vs E55 gearing?
Old Aug 18, 2009 | 04:36 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
CLS vs E55 gearing?
Hi again ...
I know... I'll stop with this soon.
Found a EGS module supposedly for a SL55 but seller says it came out of a AMG CLS... ??
Is the CLS gearing the same as the E or the SL?
No word from any of the tuners yet in getting my module sorted out yet.
Old Aug 18, 2009 | 06:07 AM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
CLS gearing is the same as E class.
their modules can, in principle, accept the 2.82 SL gearing but you need to select a different parameter, as I already told in the other 3d.
SL tcu is 035 545 1632
but, again, first best bet is to find an SL55 owner willing to let you swap his tcu and see if asks for a vin synch or not ..
if it asks for vin synch, you'll need a DAS developer in any case because normal DAS can make vin synch only from a new virgin module. AFAIK !
.. but you have also the chance that it could work without doing anything !
Old Aug 18, 2009 | 06:19 AM
jikjak's Avatar
CLS55 AMG & RRS S/C
what are the pros and cons of changing to the 2.82 SL gearing?
Old Aug 18, 2009 | 06:51 AM
dyno's Avatar
anybody out there who have 2 AMG 211E55 or 1 211E55 and 1 CLS55 willing to swap their TCU modules and see if they work without any need of VIN synch ?
should the outcome be positive, swapping to 2.82 ratio could become something really easy !
...for those who love shorter gears
Old Aug 18, 2009 | 07:04 AM
stevebez's Avatar
Hmm I was given 034 545 15 32... from MB off a SL55 VIN?
I think Ill drive to kleemann and let them work it out... they dont answer any mails!
Also I dont have DAS (at least not one thats working)...
Working without doing anything sounds way to simple for MB ...
Old Aug 18, 2009 | 07:07 AM
dyno's Avatar
that's a CLS55 EGS
re:
"Working without doing anything sounds way to simple for MB ... "
.. not true: you indeed worked hard swapping your differential with SL's one!
Old Aug 18, 2009 | 10:28 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
i have had my TCU swaped...doesnt work with just plug n play u go into limp mode
Old Aug 18, 2009 | 11:18 AM
dyno's Avatar
swapped with what ?
Old Aug 18, 2009 | 02:21 PM
stevebez's Avatar
I believe a better mid range acceleration and higher Vmax. Out of the hole potentially slightly worse because of traction problems - but hopefully Quaife will help in that regard. MKB and a bunch of euro tuners offer it as a complete kit. I did the diff part myself and trying to sort out the software now.
Kleemann came back and will do the software for $800 - seems a bit steep for only fiddling with a few parameters. Its quite a bit more than the whole diff cost!
I'll dig around and mbe convince my friend with the SL55 to lend me his EGS for a short while.
Old Aug 18, 2009 | 02:24 PM
stevebez's Avatar
It seems the ECU and EGS need to be synched up one way or another.
Old Aug 18, 2009 | 02:34 PM
Zod's Avatar
Zod
lets just say i went a bit further n tried to get the M1/M2 from an SL...R
Old Aug 18, 2009 | 04:18 PM
dyno's Avatar
if you tried to plug an SLR's TCU ... no wonder it was not plug n play
that one does not have the 2.65 ratio embedded, while SL55 tcu, does.
do you have a pic of the M1-M2 switch in SLR ?
