CM30, FD H/E Install Pics on mekantor's car. PICS
These HEs should be shipped pre-drilled IMO.
2005 BLK/BLK E-Double Nickel.
Not bad, its soft alluminum. Measure thrice, cut once. When I'm around my drill bits again, I'll tell you which size I used. They holes were big enough to just barely let the bolts through, but the bolts were tapping the holes as they went through, so the nuts were not even needed afterward, but 3 of 4 were still put back on. The 4th nut didnt have enough clearance from the outside of the HE to turn on the bolt, I might grind down and it's built-in washer and put it back on.
Alright Thanks...
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
stupid question of the day -- If i had a spare stock HE unit -- could i run 2 stock HEs if I can find room???
