Any pointers on how to get an under 2 sec 60'?
On my three best 60 fts ever just a few weeks ago I did infact power brake lightly maybe max 1200.
The key is not depressing the brake pedal hard, just lightly hold the car, step on throttle as it begins to inch rather than depress the brake lighten on the throttle instead.......
There are not much hp gains at all for this car , the stuff you are talking bout likely gave you less than 20 hp. I am fairly certain Zax63 has the stock record , its not on dragtimes but it was 12.3x , I hope you shoot shoot for the record man once you solve the 60 ft times.
FYI
my car is 12.07 and that is on a 81 degree day.
The top non nitous pass is 11.97 rarfinancial
The quickest on nitrous is 11.66 rarfinancial
Your doing big things , looks like the air up there is good, go for it man.
2005 Mercedes G55 AMG
I used to just roll into throttle no power brake.
The key is not depressing the brake pedal hard, just lightly hold the car, step on throttle as it begins to inch rather than depress the brake lighten on the throttle instead.......![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
FYI
FYI
One more thing, I have H&R 20 mm spacers installed in the rear, do you think I should remove them or it doesn't matter?
Also, traction on or off?
But you are similar to my car and a better wheel set up would likely have you right at 12@116 just like my car. Im maybe 20 hp over stock Rick is likely 70 hp over plus a 75 hp shot when needed.
You definately could hit 12.20's as is with a small 60 ft improvement a low 1.9 high 1.8 should get you 12.20's
