Today at the drag strip...
what was your 1/8th mile trap speed during the 115 mph pass
what was your 1/8th mile trap during the 120mph pass
also please post up weather data from each date.
This will help narrow the possible cause of the 5 mph lower 1/4 mile trap.
ooops sorry my bad.
ok here is the info.
1/8 trap is 92.56MPH (12.073@120.11mph)
i wasnt able to do another run that night because it started to rain as i was lining up. the weather that night was:
August 28, 2009 10:26pm at Mission, BC
Max Temp: 26.7°C 80F
Min Temp: 11.5°C 52.7F
Mean Temp: 19.1°C 66F
Precip Accumulation: Trace
1/8 92.87 (11.853@115.96mph)
they called off the drags this night because the dew point was too high, the weather that night was:
Sept. 25 9:18pm
Max Temp: 22.4°C 72.32F
Min Temp: 7°C 44.6F
Mean Temp: 14.7°C 58.46F
Precip Accumulation: 0 mm
Sept. 25 9:18pm
Min Temp: 7°C 44.6F
anyways im excited for later on today because ill finally be getting my custom dyno tune. the PC boys have arrived, great guys!
#33
BTW great job on getting your 60 ft down and achieving sub 12's passes
#34
went to the strip last night and here's my best time.
i think i need to get that rear reservoir. maybe thats why my traps arent higher.
11.609@120.65mph
60' was 1.735
11.609@120.65mph
60' was 1.735
#35
Nice runs jikjak! Keep up the good work. I'm sure you will get those numbers down. It's great to see people consistently running in the 11s with the 55's ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I wouldn't doubt it. Ive seen stranger things happens at the track. 119mph is really high for stock though. But, wasn't that because you spun and got a worse 60 foot then your other runs?
Just my 2 cents. I only count my runs with traction. For example whatever my mph was on my lowest et run. Mph increases slightly with less traction. I'm sure you already know.
#37
So far to date all my records were broken with the same pass. This would be a good indication of a clean run.
#38
Nice runs jikjak! Keep up the good work. I'm sure you will get those numbers down. It's great to see people consistently running in the 11s with the e55s. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Just my 2 cents. I only count my runs with traction. For example whatever my mph was on my lowest et run. Mph increases slightly with less traction. I'm sure you already know.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#39
#40
Like I mentioned to you, find your bottle neck and fix it. The only way to do this is to data log your runs.
#41
ya im going to get my hands on one and see what it can tell me.
theres something going on with my ride, im thinking its heat or pulley related because i noticed the difference in the top end after changing over to the 180mm. it seemed to pull better up top with the smaller pulley and i was hitting 120mph before with that pulley.
on a side note i raced my friends modded gtr last night on a hwy run. i used to lose to him by about 1.5-2 cars and this time i was able to pull about half car ahead of him and it seemed like i was going to be able to pull farther ahead but then we ran out of room!
#42
2008 A8L, 2002 996TT X50, 2009 X5
I think most reasonably agree, however, that once you mount up some DR's, you're no longer putting down a "stock" run. DRs are one of (if not the) most effective mods you can do on a 55K car.
Incredible performance, nonetheless.
OP - congrats on the 11's... nice numbers!
#43
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Jikjak, Do you have any cooling mods yet?
#44
Adding DR's, you'd definitely go quicker... maybe faster, maybe not - but I'd give it a "probably."
Incredible performance, nonetheless.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
