E55 Squeak Eradication
Old Aug 31, 2009 | 08:51 PM
RACE_MX's Avatar
GLE55
This is the first car I've owned that has squeaks in Dolby Digital Surround Sound. It's a lot of work but I'm going to R&R the car's entire interior and coat everything with Plasti Dip. I saw this stuff at Lowe's recently and decided to try it and it's the best product I've found to eliminate the annoying sound of plastic rubbing together. I did the entire center console yesterday and the first door panel took hours to disassemble, coat and re-assemble.
Old Aug 31, 2009 | 09:43 PM
Objectionable's Avatar
E55 AMG
Best of luck with the project. The weather has been cool for the last few days and my car has started to chirp and squeak. I press the accelerator and it seems to go away.
Old Aug 31, 2009 | 09:48 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Be carefull with the air quality inside your car, by adding all those VOC`s (volatile organic compounds)..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
