Noise from the climate control?
Need a little help. When I start the car for the first few minutes, there is a squeeking sound from the right of the dash. If I turn the climate control off, it goes away, but doesn't seem to be dependant on the speed of the fan.
Any ideas? Thanks
Any ideas? Thanks
2015 S212
Check the vents and make sure they are open. If you close them, they squeeeeek as air squeezes through.
Just re-read. Only at start-up then gone? If so, it could be the seal closing for the circulated air. Basically filter online or filter offline. Is your cabin filter cartridge old?
