COMMAND switching on and off...
Old Sep 25, 2009 | 01:08 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Had the PerformanceBox on today and the power lead running across the COMMAND screen... and the COMMAND keep switching on and off ... moved the power cable to the right of the screen and it stopped ....
Wierd right? Coincidence...? maybe a loose contact in the NAV in the trunk or could the cable cause this interference?
Old Sep 27, 2009 | 05:03 AM
stevebez's Avatar
FYI -...
Its not the cable - did a few times for no reason... I think my Nav DVD could be faulty.
Old Oct 3, 2009 | 02:12 PM
stevebez's Avatar
Just an update on this one again.
If I am listening to the radio, the system will switch off. !0-15 seconds later it cylces on again on the NAV page.
Today it did something even more wierd ... switched off and switched on again in German. The AMG logo on the headunit was gone and the MB badge was there.
I change the language back to english and viola the AMG logo is back etc .....
I recently installed the NAV disc to the latest version but it seems to be corrupting the system.... anyone have a similar experience?
There is no loose connection - I checked - so has to be the firmware / nav software...?
Old Oct 3, 2009 | 05:09 PM
Karlson's Avatar
06 E55
Did you try to put your old Navi disc back? I just got Navteq 8.0 and it was very slow in the begging and screen was blinking! Did you update Command with a newer software?
Old Oct 4, 2009 | 04:46 AM
stevebez's Avatar
I went from ver5 to ver10 (euro) so perhaps I need the updates in between?
I tried cycling between the two versions but the system seemed to get stuck at some point. Now I have the new version in and running so will see how it goes.
Would be handy to know if there is a way to force an update with the current disc installed.?!?
Old Oct 4, 2009 | 11:35 PM
Karlson's Avatar
06 E55
you can update command in dealership or download update CD from Torrent. The service update disc is less than $20 at dealer.
Old Oct 5, 2009 | 07:55 AM
stevebez's Avatar
Got the new disc in and running fine now ... wierd.
Lets hope it lasts.
Old Oct 13, 2009 | 11:27 AM
stevebez's Avatar
Well it's back ... No reason just switches off and then switches on again. This time it switched off while playing the radio and switched back on playing the a cd in the front slot.????
Friggin wierd... Then it's fine for the rest of the day. Removed the CD and let's see what happens now....
Thing is it's been fine for a week and now starts acting up again???
Old Oct 15, 2009 | 05:39 PM
stevebez's Avatar
OK after complaining it was the NAV system making my system play up it seems its the new iPhone cradle...
The pairing between the COMAND and the unit apparently was a bit dodgy (if that is possible) and / or the cradle was not seated properly in its connector.
Either way no COMAND reboots after a removal / refit / re-pairing ..... yet. However I am not holding my breath.
FYI I found the source of the problem via the Engineering mode ... once you in there go to top right "errors" and scroll through them ... out of the 50 listed (I think it only lists 50), 45 of them related somehow to "addressbook" ... Bingo!!! the time / miliage stamps confirmed it.
I had no clue what the other errors related to , but mentioned low voltage amongst the HEX codes.
