Big traction problem
I feel like I'm back in Boston in the winter time except its 85 out and sunny.
I know nothing will totaly solve the problem, but if I can cut down on the issue that would be good. No joke I'm braking the back end out at highway speeds if I romp on it. I might just add sandbags in the trunk.
Time to just go NITTO drag radials.. You know that is your best solution. Invos or NT-05s will help but you know deep down in your heart that it is DR time..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Exactly, anyway you chop it up. With the power you're pushing. You will need a stickier compound tire. Might want to consider BFG drag radial. I have found them to superior to the nitto drag radials. Also, getting the car to squat will help plant the rear tires and apply more power to the ground. Not sure if you have a really stiff setting on you suspension. But, every little bit helps.
The Nitto 555 street tire is an old model... old design, old compound, etc. I'd suggest you try the Dunlop Z1SS's, Nitto NT-05's, or Toyo R888's - any would be a huge step up from your current setup. 10k, BTW? LOL... with the amount of torque you're pushing, if you went to any of those (especially the R888), you'd be closer to the 5-7k range 'til they're toast if I had to guess.
Good luck and keep us posted on what you choose.
