When I put the E63 in reverse...
Old Oct 6, 2009 | 02:46 PM
RobDoc's Avatar
E63, M3 SMG, F355GTS
...I would like the passenger-side mirror to tilt automatically. Can you set the car to do that?
Old Oct 6, 2009 | 02:47 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
My understanding is it can be enabled at the dealership.
Old Oct 6, 2009 | 02:55 PM
Cypher94's Avatar
Depends on the season
On the E55, there is a setting you can set through the display. Maybe its the same for the E63? On a side note...that function stopped working for me after I took my car to the benz dealer to get some work done and the setting in the dash didnt help lol.
Old Oct 6, 2009 | 03:04 PM
sunny_j's Avatar
09 E320 Bluetec
on the drivers door press the passenger side mirror button in and then when you go in reverse the passenger mirror will tilt. if the driver side mirror button is pushed in then the passenger mirror wont tilt.
Old Oct 7, 2009 | 02:09 AM
RobDoc's Avatar
Nope. Doesn't work on my E63.
Where exactly would you look for that "setting" in COMAND?
Old Oct 7, 2009 | 05:08 AM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
There's been a lot of discussion in the W211 boards on this. It was decontented in the newer W211s and the dealers can't activate it either. Apparently it didn't work too good anyway and MB removed it.
You can do a work around by setting up the passenger mirror to point down as you want it and then 'sacrifice' a memory setting. Then when you put it in reverse, hit that memory setting so the passenger mirror goes down. Then hit your regular memory setting back on when going back into drive. Tedious.
Old Oct 7, 2009 | 08:30 AM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
it is not in the commad it isin the cluster
Go to the menu that says
-settings
hold reset button for 3 seconds
then hit one of the folder buttons
now go to convenience
from there you can make the adjustment
Keep in mind i have an 2005 e55, not sure if there are any differences
Old Oct 7, 2009 | 09:59 AM
Cypher94's Avatar
What top end said except on mine I dont have to hold the reset button down. I can just hit the folder button once I get to settings. I have an 06.
Old Oct 7, 2009 | 10:15 AM
TopEndS62's Avatar
Yes.. but i never said for him to actually hold the reset button.... settings
is what is diplayed before you hit the folder button..
Old Oct 7, 2009 | 10:25 AM
Cypher94's Avatar
woops...read it too fast lol
TopEndS62's Avatar
its cool
Old Oct 7, 2009 | 08:47 PM
220S's Avatar
Only prob is the OP has an E63
The reverse mirror has been decontented on the later E63. You guys keep talking about the E55....
Old Oct 7, 2009 | 08:54 PM
Karlson's Avatar
06 E55
this forum belongs to E55 Just kidding. I think MB did removed that feature.
Old Oct 8, 2009 | 01:07 PM
Cypher94's Avatar
I know he has an E63...I was just stating how to change the feature in an E55
Old Aug 17, 2010 | 02:43 PM
VinceB's Avatar
'08 E63 - P 30, 66GT 350 (sold)
I have an '08 E63 and just tried to set it. The manual says to press the memory button and w/in 3 seconds press the down mirror button while set to the passenger side mirror. Only problem, doesn't seem to take the setting.
I'm heading to the dealer if I can't get it to work... in the manual, should work. I've dinked with it for 20 minutes trying different combos, holding the memory button while pushing the down button, press release the memory button then the down button, etc. etc...
Old Aug 17, 2010 | 03:00 PM
citylightva's Avatar
2007 E63, 2005 Dodge Ram Hemi
It's old thread week ...The option is in the menu in your dash under vehicle settings...It asks if you want to enable reverse mirror...Then when you put it in reverse and it tilts down you can set it to where you want it when it's tilted, then once in drive again you can set that to where you want it and all should be good....
Old Aug 17, 2010 | 04:01 PM
220S's Avatar
Originally Posted by citylightva
It's old thread week ...The option is in the menu in your dash under vehicle settings...It's ask if you want to enable reverse mirror...Then when you put it in reverse and it tilts down you can set it to where you want it when it's tilted, then once in drive again you can set that to where you want it and all should be good....
fwiw, it know was decontented in later models. The 2009 doesn't have it and apparently neither does the 2008(?) The dealer can't (won't) enable it. At least not for me.
Old Aug 17, 2010 | 04:05 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Interesting...... I have it enabled in my car
Old Aug 17, 2010 | 04:14 PM
Really..?? Now that's just f'in weird...It's not like it's extra hardware...Simple line code...
Old Aug 17, 2010 | 04:16 PM
VinceB's Avatar
Figured easier to search old threads than start fresh and be told to search
Something must have changed in '08 as I went through the settings on the dash, even the manual doesn't say anything about enabling the rear view mirror via the Vehicle sub menu- only automatic lock setting and Audio search, and tail gate height for wagons...Convenience doesn't cover it either.
Per the manual, it's just selecting the right side mirror, pressing memory (I assume release the memory button) then push the bottom of the 4 way adjustment again w/in 3 seconds to save the position... think I maybe stuck on this one
It shows it in the Operator's manual so I plan to raise a stink at the dealer if it's really been decontented. Like Citylightva said,the functionality is there, only code. Why eliminate?
Old Aug 17, 2010 | 04:24 PM
220S's Avatar
There's been a lot of talk about this here and in other MB forums. As Vince says, it's in the manual but it doesn't work. Apparently MB decontented it (looks starting with the 08 model) because it wasn't working right and people were having issues getting it to return back up, iirc.
The dealer said it's "gone" from the system.
Old Aug 17, 2010 | 04:31 PM
clkwork's Avatar
CLK63 Black Series
It was a pretty neat feature, they should have kept it. I had it on my old CLK but the black series lacks it. It was great for making sure you don't curb the rear wheels when backing into a parking spot.
Old Aug 17, 2010 | 05:23 PM
I was just messing with you...I will say it does act up sometimes, but my SA told me how to fix it...If they ever don't tilt back up you just have to readjust while you're in drive to the proper position...
Old Aug 17, 2010 | 08:48 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: E63 Mirrir Tilt
Sometimes these old threads are not a bad thing.
I was not aware the 07 E63 still had this feature, thought it had been decontented. My SL600 has it and it works perfectly, heck even my 03 BMW has it....loud by still operative. I'll try to set it next time I drive the 63.
Old May 3, 2012 | 11:44 PM
IndiumGreyE63's Avatar
2008 Mercedes Benz E63 AMG, 2017 Porsche Macan S
Red face Passenger Mirror Tilt on E63
This is odd. I brought my car in a couple of months ago to the dealership for "Service C". And the other day, I noticed that when I go into reverse, my passenger mirror automatically tilts down.
It never did that before! I have to ask the dealership what they did....
Either way - I like it!
